Schumacher Battery Charger problem
I have a wheeled Shumacher battery charger that won't charge, any thoughts? It is a 2amp / 20 amp / 40 amp / 200 amp with a timer. The fan comes on but there is no output voltage to the cables. It doesn't look like there is anything fried in the transformer and the breaker on the ground cable is ok.
Those Schumacher units have a cheapo rectifier assy in them. They are mostly junk. They are repairable if you find the right parts but if that rectifier setup is blown it is probably better to buy a new unit that is not made by Schumacher. Some other name brand units are also made by Schumacher so look closely.
I have not bought a new unit for years. I have a couple of those Schumacher units in the junk pile tho that were purchased by friends. Just take a look inside your unit, then when you go looking for one. Peek inside with a flashlight at the rectifiers and don't get anything that looks like it.
My Schumacher charger died recently as well.It works on the boost setting but not on charge.I was looking at the battery chargers at Wal-mart and noticed that the Schumacher ones are made in Mexico now, but the one I have was made in the USA and is only a couple of years old so they must have just recently moved their plant.Wal-mart had a charger called a Smart charger for $18 that uses some sort of new technology and only weighs a couple of pounds so I bought that one and it seems to be working fine so far.
Shumacher / napa battery charger- no power
It doesn't take much to get a bad contact and lose either one setting or all the power out. Mine lost all the power as they tried to use one wedge spade to connect the over temp unit to the transformer wire. (2 wires at once). there was a small
melted spot near where the 2 wires touch. I had to remove a few pieces of plastic and connect the wires vis solder. For single wires, you just solder the spade clip to the single wire.
Received 3,192 Likes
on
The following users liked this post:
oxt127
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-06-2017 12:46 PM
VindexInjuriae
08-14-2014 05:43 PM
