High EGTs
Old Jan 4, 2006 | 06:31 PM
idcpa's Avatar
idcpa
High EGTs
Hello,
I have a 1996 F350 Powerstroke that I bought used. I have added a Banks exhaust brake which replaces the entire down pipe, a FTVB on the automatic transmission, and a 3 gauge pillar mount. The truck has a 3.55 rear end. I had a Jody Tipton 60hp PCM installed, but when towing my 28' fifth wheel my EGTs would constantly go into the red zone, and I would have to back off of the throttle. The pyro probe is mounted pre-turbo. I put the stock PCM back in, and when towing my fifth wheel up a steep grade my pyro would go just to the edge, or slightly into the red. When running empty the gauge can get into the yellow if I get into it on a hill, and when traveling 65 mph the temps are 700-800 degrees (stock programming). Does this sound right, or are my temps too high for some reason? The truck has a cat, but a muffler shop checked it and said that it was not plugged. If I were to try chipping it, I'm afraid the EGTs would get too high, and I couldn't use the extra power, like when I had the Tipton PCM. I have the stock airbox with a new NAPA Gold filter, and the exhaust is stock. Does anyone have any experience in this area, or have any suggestions? I appreciate any insight and/or advice. Thanks in advance!
Old Jan 4, 2006 | 06:37 PM
jcab's Avatar
jcab
You need to delete, or gut the cat. Also install an open air element, and at least a 4 inch exhaust. These mods are the first things to do to get egt's down, as well as gauges to monitor everything. Jeff
Old Jan 4, 2006 | 07:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That is to be expected when running a chip. An upgraded intake and exhaust are the most basic requirements for running a chip...or retuned PCM.
700-800 empty is kinda high...maybe that brake isn't opening all the way?
Old Jan 4, 2006 | 08:02 PM
hucka1a's Avatar
hucka1a
definatly get rid of that cat and check into getting a better filter system. If your really serious cram in an intercooler.
Old Jan 4, 2006 | 08:14 PM
444dieselrod's Avatar
444dieselrod
Definetly ditch the stock box. the added air will help keep your EGT's down, and give a slightly better pulling feel, from the faster spool up.
Diesel Rod
Magnolia Tom
Feb 27, 2015 02:52 PM
Christof13T
Sep 18, 2012 12:52 PM
jonesy23
Sep 13, 2006 10:04 PM
why165
Feb 3, 2006 12:01 PM
artj
Exhaust Systems
Nov 2, 2005 05:20 PM
