Modular V10 (6.8l)
skip and missing v10
Old Jan 9, 2006 | 06:34 PM
73F100*8Mile's Avatar
73F100*8Mile
fixed! what was happening was the vacuum line was collapsed in on itself so it would pull air in causing a leak and then when the computer would correct the irregular idle with the IACV activating it would push the vacuum line shut and seal itself causing a smooth.....rough....smooth.....idle. we fixed it with some "red" oil proof 5/8" heater hose and it fit nice'n snug. our van has 127,000 on it so if your van is close and it starts to do the above...check that vacuum line first. just pull the intake plenum tubes off all the way back to the butterflys and right below them on the outside is that 5/8" port pointing towards the front of the van. hope this helps!
Old Jan 9, 2006 | 07:16 PM
NoMo's Avatar
NoMo
Great! Thanks for sharing the solution to your problem. It'll probably help someone else one of these days.
Old Jan 9, 2006 | 09:15 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I just put this gem in the great chasm of crap called my brain
Codeman894
Apr 4, 2024 09:52 PM
amdriven2liv
All Things Towing
25
May 24, 2017 06:23 PM
Jacob Gervais
Jul 11, 2016 02:47 PM
grizz 454
Aug 23, 2015 12:30 PM
Feonix1123
65
Apr 28, 2013 09:39 PM
