Boost gauge tap location
Old Jan 1, 2006 | 05:37 PM
plowhand's Avatar
plowhand
Playing in the Dirt
I have a '95 F250 and I'm going to tap into the turbo "Y" pipe for my boost gauge. Does it matter and will it affect the readings if I drill and tap into the side of the "Y" pipe or the front of the "Y" pipe.
Someone told me that if you tapped into the side of the "Y" pipe the readings would be off (on the low side) due to the air going past the fitting and not at the fitting as it would be if tapped into the front.
Thanks for your help, this is a great site, and may everyone have a GREAT NEW YEAR
Old Jan 1, 2006 | 07:22 PM
1997F-350's Avatar
1997F-350
most folks on obs trucks tap into the map sensor line....
the only reason i would not do what you are doing is shavings unless you plan on pulling the y pipe to tap it...but thats just my opinion..
fwiw here is how i did mine good luck
http://community.webshots.com/photo/...94236665ctJNLt
knottyrope
Nov 17, 2024 04:42 PM
GaryKip
154
May 15, 2017 07:23 PM
BBslider001
Sep 11, 2016 05:09 PM
hollenjoe
20
Jul 31, 2007 06:01 PM
fordborn
Kansas Chapter
32
Dec 12, 2004 03:31 PM
