Computer Pop Ups!!!!
Old Dec 31, 2005 | 06:02 PM
mantta's Avatar
mantta
I keep getting these pop ups from http://ad.oinserver.com. They just started yesterday and I can not stop them even with my pop up blocker set to the highest setting. Has anyone out there had this problem? If so I sure could use some help on how to get rid of this agonizing problem.
Thanks,
Larry M
Old Dec 31, 2005 | 06:22 PM
Crash687's Avatar
Crash687
sound likes spyware, try down loading Spybot Search and Destroy, update it and check for problems, also there is an option to imuniuze your computer.
you will probably get a few other suggestions for spyware, there all godd and alot better than nothing.
Old Dec 31, 2005 | 06:23 PM
jake00's Avatar
jake00
I'd check your "ad remove programs" feature in the control panel for any bogus progs
Old Dec 31, 2005 | 08:58 PM
924x2150's Avatar
924x2150
Search Ewido Anti-malware try their free download... It takes a long time to scan though...install it, go to safe mode, start the scan and go to bed...scan takes about two hours.
You better try MS antispyware beta 1 also.
If that doesn't help, go to Majorgeeks.com they can help.
Old Jan 1, 2006 | 12:08 AM
rhw's Avatar
rhw
Download the Google search bar - has a really good built in pop up blocker!
Old Jan 1, 2006 | 12:22 AM
donjamer's Avatar
donjamer
Thanks,
Larry M
Mantta,
Since they just started why not run System restore and roll back a few days. Make sure you select a day before it started. That should fix it. Then make sure you run a spyware blocker. I use spywareblaster and spybot on all my and customer machines. They are free/donation ware programs.
You run system restore from the start menu under accessories then system tools. Just in case you don't know where it is.
Old Jan 1, 2006 | 12:35 AM
jpjahn's Avatar
jpjahn
https://www.ford-trucks.com/forums/s...d.php?t=439070
We had a problem like that. See if anything helps out.
Old Jan 1, 2006 | 11:00 AM
mantta's Avatar
mantta
I tried to run the system restore. I was unable to back up the date to restore it to.
Thanks,
Larry M
Old Jan 1, 2006 | 11:27 AM
preppypyro's Avatar
preppypyro
Alot of times too, a guy will get stuff like that popping up when they ahve installed different types of programs, could check that out also.
bashby
19
May 7, 2009 07:39 AM
fordmarshall111
19
May 13, 2005 05:10 AM
thunderguns71
13
Jan 16, 2005 10:15 PM
Andysutt
24
Jul 7, 2004 05:57 PM
Sudsrat
Jan 11, 2004 07:52 PM
