1978 - 1996 Big Bronco
Tailgate/window switch
Old Dec 23, 2005 | 07:43 PM
1970Custom's Avatar
1970Custom
How does the switch in the TG work?
I'm replacing the window motor and tried to accuate the motor via the switch but on the inside of the tailgate with a screw-driver and got nothing, does it have to have the lever on the switch touch to make the circuit?
Does the casing make the ground when in place?
Sorry for the rambling.
thanks in advance,
Old Dec 24, 2005 | 02:52 PM
greystreak92's Avatar
greystreak92
The t-gate switch for the window is actually TWO momentary push-button switches that are activated by a paddle on the tumbler mechanism. When the key is inserted and turned, the paddle swings around and presses one button or the other depending upon which direction the key is turned. The ground for the tailgate power is actually fed all the way from the ground lug up behind the emergencey brake pedal. It runs through the dashboard switch first then continues back to the keyswitch and through to the window motor. This prevents a short circuit should both switches somehow be activated at the same time since the power (+ pos.) is fed by two separate circuit breakers for each switch. The CB in position 12 feeds power to the keyswitch and the CB in position 14 feeds the dashboard switch.
Old Dec 24, 2005 | 09:01 PM
1970Custom's Avatar
1970Custom
If you were to push the momentary switch from inside the talegate would it activate the window motor?
Old Dec 27, 2005 | 04:30 PM
greystreak92
In theory, yes, it should. If it does not, check the wiring harness particularly between the gate and the jamb. If that checks out, circuit breaker 12 may be a problem. If THAT checks out AND the window works using the dashboard switch, swap the CB's in positions 12 & 14. In the event NONE of this gets the window moving with the keyswitch, the problem is more than likely the switch(es) themselves or the safety interlock switch on the driver's side latch. (The safety interlock would keep the window from moving with either switch though).
Old Dec 27, 2005 | 05:36 PM
1970Custom's Avatar
1970Custom
Are these easly replaceable?
Old Dec 27, 2005 | 05:43 PM
Streetgang's Avatar
Streetgang
Most people just jumper the safety interlock switch out.....then you just have to be smart enough not to open/close the TG when the glass is up....
I did jump out the safety on one of my Broncos and never looked back.....drove it like that for quite a long time with no "problems".
Old Dec 27, 2005 | 05:57 PM
1970Custom's Avatar
1970Custom
Only problem I have now is getting the window down to do/fix this.
Old Dec 27, 2005 | 06:45 PM
Streetgang's Avatar
Streetgang
Here is some VERY good info on how to do just that........
http://www.supermotors.org/vehicles/...=12689#content
Dlooman
Mar 23, 2012 08:36 AM
BxTCHIE1
Mar 2, 2011 11:35 PM
96broncoXlt
Jan 20, 2007 03:58 AM
Texas Ex
Apr 24, 2004 08:43 AM
baw289
Jan 29, 2004 04:15 PM
