1978 - 1996 Big Bronco
Tailgate Closed Safety Bypass
Old Apr 23, 2004 | 10:43 PM
Texas Ex's Avatar
Texas Ex
Hello all:
Does anyone have directions on how to bypass the safety switch that keeps the rear window from operating if the tailgate is not fuly closed?
Thanks for the help.
Old Apr 23, 2004 | 11:28 PM
bigric's Avatar
bigric
Take off the interior tailgate panel, reach around to the driver side hinge, unplug the sensor, and short the 2 wire connector with a wire (preferably with 1/4" spades attached, but for the short time a wire will do). I've been doing this for years.
Old Apr 24, 2004 | 08:43 AM
gman88's Avatar
gman88
I have done this on many occasions when the window failed to go all the way up due to rust and lack of lubrication.
All you need to do is latch the drivers side latch while the tailgate is in the down position. This fools the tailgate closed sensing switch and allows you to actuate the window up and down using the key in the tailgate.
It has been a while since I have done this, however it think it will get you started. Just remember to un latch it and have your window down prior to closing. Also a good idea to have someone support the window if the gate is down and the window is fully extended.
Good Luck
guessrow
2004 - 2008 F150
23
May 7, 2022 05:01 PM
copper0848
Aerostar
Feb 24, 2007 03:07 PM
beaver24
Sep 30, 2004 02:23 PM
Wakeboarder141
Dec 15, 2003 07:04 PM
