Fuel Tank 59 Panel
krautwolf,
Not sure about the wing tanks. My advice is to get the straps from the same application that you got the tank from. I recently installed a tank from a mid 80's Blazer in my 49 (I got the tank for free and it fits great) I went to the wreckignyard and pulled the straps from a blazer and then made the appropriate brackets to hold them. I now have 34 gallon capacity (bit excessive but beggars can't be choosers)
I would imagine that a wing tank should be similar
Good luck
Bobby
Good luck
Bobby
I have been doing a lot more searching online for the side mount tanks (sizes in various vehicles and availabilty---used).
I just happened to find a site where the owner used a ranger tank in his. For all I know it might be a member here, but I don't recognize the truck. The gas cap is in/on the drivers side fender where my spare mounts now.
Page 1 with information:
http://www.winfordr.com/54f100.htm
Page 2 with pics:
http://www.winfordr.com/FordTruckStuff/54truck1.htm
Most of the rangers had 17 gallon tanks that I have seen (my 89 did), but I think some were smaller. For those who are going EFI, the ranger 2.9 started in 85. I believe they had an in-tank pump (would need to be varified). I know for sure the 89 did. I put a carter pump in mine.
A ranger tank should be easy to find (w/pump and sending unit). I assume 17 gallon would be suffiecient with a 302/AOD. Not great, but......it would not sit as close to the ground either.
Hmmm...reverse a second one later and put it on the other side?
Don't know if this helps anyone, but I thought it was a good idea.
Page 2 with pics:
Bigdon68
Fifth Wheel & Gooseneck RV Towing
53
12-18-2016 04:15 PM
ktm4012
06-13-2016 10:12 AM
