400 pinging
Old Dec 26, 2005 | 05:56 AM
Strokin' Ace's Avatar
Strokin' Ace
I have replaced the plugs with Autolite 26's & to my surprise, no ping. I have 92 octane in it now. Will be curious if I will have the same results with 87. I am surprised that no one on here recommended trying hotter plugs.
Old Dec 26, 2005 | 09:27 AM
derherr65's Avatar
derherr65
Hotter plugs usually cause more pinging problems. How do you know that the Autolite 26 is a hotter plug than the Motorcraft Afs-42c?
Old Dec 26, 2005 | 03:34 PM
Bill_Beyer's Avatar
Bill_Beyer
Maybe your truck just likes Autolite spark plugs better than Motorcraft. I personally use only Autolite in my engines.
Old Dec 26, 2005 | 04:27 PM
koja one's Avatar
koja one
Trailering
strokin,I've had this problem when replacing my dist.either used or rebuilt,replacing the vacum pot or egr was'nt workin.In each case these distrubutors will over advance upwards to 60 degrees.We have bought dist. for 70's f-350 and sometimes this works.car dist work at low rpm,so that there's quick advance,this won't work in a truck.An old fordman racer that i use to know would take my dist. apart undo the centrifugal advance springs pull the wire clip out under the felt oiler in the center of the main shaft,pull it up, turn it 180 degrees to the other gapstop.If he went to the wider gap, he would run without the vacum advance if total advance was around 40 degrees.If he found it already on the wider gap he'd go to the narrow gap and start trying different vacum pots.remember after you do this you have pull the whole dist. up and restab it in the engine 180 degrees keeping your vacum pot in the same position.I always put the engine on tdc #1 cylinder before I start.Sometimes the little tab had small piece of hose on it to limit advance travel.these most of the time are gone which will make over advance.He built me a 460 for my f 150 which had no problem in kansas.took it to colorado hunting loaded down,it pinged.got to durango fliped the dist.guts around 180 degrees,unhooked the vacum advance timed at 12 degrees,total advance was 42. no ping,13 mpg in the mountains.10 mpg in kansas. you need some vacum advance for fuel mileage. I got a couple trucks this way ,sometimes you got replace those tired springs and stuck wieghts.msd and some of the aftermarket hei for ford work well if you are willing to tune.
Old Dec 27, 2005 | 05:44 AM
Strokin' Ace
Standard Autolites were 25's. Parts store person said 26's were hotter. That's what I got. I haven't pulled one to look yet. I am going to do that now. Thanks!
Old Dec 27, 2005 | 06:05 AM
Strokin' Ace
I pulled a plug. They look real good. Light tan. My goal now is to get this thing to run on 87 octane. Is it really true that a hotter plug will increase ping? I stepped up one step hotter & the ping stopped. Granted, I had the motorcrafts in there before the autolites. If this is true, sounds like I should go & get a set of Autolite 25's? I will probably get a tank of 87 first. Any opinions?
Old Dec 27, 2005 | 12:36 PM
beeboy's Avatar
beeboy
Another factor can be the carb. That 1406 is a bit lean out of the box, and running lean can also cause pinging issues. Look at the charts in the book for the carb, and think about trying to increase your cruise mixture 1 step richer.
Old Dec 27, 2005 | 07:01 PM
Bdox's Avatar
Bdox
Just looked it up. With Autolite plugs, the higher the number the hotter the plug.
Whatever caused the decrease of pinging, it is unlikely that hotter plugs brought it about.
Carbon deposits, overadvanced timing, lean mixtures, excessively hot plugs, overheating can all contribute to pinging.
Changing the plugs may have dislodged a bit of glowing carbon. (?)
Old Dec 27, 2005 | 08:39 PM
roger dowty's Avatar
roger dowty
I would not get a full tank quite yet.
Old Dec 28, 2005 | 06:14 AM
Strokin' Ace
Interesting! I guess for 10 bucks I may as well get a set of 25's & try them. From the sounds of the opinions here, I should have more luck running 87 octane with 25's than 26's, right?
Jimmy Pet
Modular V10 (6.8l)
127
Aug 4, 2019 01:21 PM
sudsmcduff
Jan 12, 2016 06:24 AM
vtjvt
Sep 27, 2015 02:32 PM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
MPDano
15
Nov 22, 2006 06:41 PM
