Turn signal (buzz/vibration)
Old Dec 18, 2005 | 09:19 AM
Glemch's Avatar
Glemch
When I activate my left turn signal, I hear a "Buzzing" type sound occasionally. The sound seems to be coming from the steering column, although its hard to tell. Any ideas?
Old Dec 18, 2005 | 10:45 AM
scucci's Avatar
scucci
The noise is coming from the solid state flasher, caused by poor contact in the multifunction switch( ts/wiper/hazard/high beam). The switch is $68 at ford dealers. It takes about 20 minutes to replace. I changed mine this summer. Supposedly the new switch has been redesigned to stop this defect.
Roy
Old Dec 18, 2005 | 12:01 PM
dirtydog43's Avatar
dirtydog43
Or it could be coming from the flasher which is also located on the steering colum. If you look under your dash, it's a little yellow square thing with a yellow plug. There will be 4 wires coming out of the plug. Oh yeah, what year is your Explorer?
Old Dec 18, 2005 | 04:21 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 18, 2005 | 05:45 PM
Glemch's Avatar
Glemch
It's a 1997 Explorer.
Thank You Scucci and dirtydog43, I'll try both of your suggestions.
Old Feb 24, 2007 | 06:05 PM
linckeil's Avatar
linckeil
you ever figure this out? my explorer does the same thing. now it does it every time i put on the left turn signal and the lights do not work at all. the right turn works fine with no buzzing. any ideas? i'll check the multifunction switch. where is it located?
Old Feb 24, 2007 | 09:04 PM
scucci's Avatar
scucci
The multi function switch is the turn signal lever. The only way to test it is to replace it.
Scucci
Old Feb 25, 2007 | 11:22 AM
aquanaut20's Avatar
aquanaut20
I dissassembled mine on 97 Exp, cleaned all contacts, lubricated and reinstalled, has worked faithfully for past 4 yrs.
Old Feb 25, 2007 | 03:24 PM
linckeil's Avatar
linckeil
ok, it works like a charm now. here's what i did after reading a few other posts:
disconnected negative battery cable.
removed the tilt lever.
removed the 3 philips head screws holding the column covers on.
silde off upper and lower column covers.
removed 2 torx heads holding switch on.
unplugged both plugs.
blew dust out of contacts with compressed air.
sprayed plugs and switch with $7 contact cleaner from radio shack.
put on a bit of dielectric grease.
put it all back together.
20 minute job.
if that hadn't worked, i would have bought a new switch, but i was able to save myself the 65 bucks. a penny saved is a penny earned.....
Old Feb 25, 2007 | 05:49 PM
aquanaut20's Avatar
aquanaut20
So now there are 2 of us that would rather fix than replace where possible
Old Feb 26, 2007 | 07:48 AM
mason's Avatar
mason
Ohters have successful tried spraying contact cleaner into the switch through the hazards button on top. Repeatedly push the button while spraying the cleaner. Might want to try this before disassembling.
Mason
Old Feb 26, 2007 | 08:20 AM
fmrplt's Avatar
fmrplt
Our 96 did the same thing and it was the entire switch unit that was bad. When we pulled it apart it looks like it was arcing and melted a few things in there. Like scucci says you need to replace. You could pull the unit apart and take a try at fixing it but your rig will be down for maintenance for a while. No turn signals, no wipers, no hi/low beams - it's an all in one switch.
Old May 10, 2007 | 06:10 PM
labmom's Avatar
labmom
Mason
Mason
Please
What is contact cleaner and where do I get some?
Labmom
Old May 10, 2007 | 06:52 PM
aquanaut20's Avatar
aquanaut20
Dont waste you time with the spray, either re/re or take it apart and do it right, clean and adjust all contacts. Once it was out it took 20 min to fix, you will have to take it out to replace anyway, and you might learn something.
Old May 11, 2007 | 07:44 AM
mason's Avatar
mason
Your can get contact cleaner at any good auto parts store or at Radio Shack. Comes in handy. I used it on my irragation system control recently.
Mason
Rusty01
Electrical Systems/Wiring
25
Nov 11, 2019 07:54 PM
V10man
Aug 1, 2016 09:50 PM
hgoalie
Aug 30, 2013 04:59 PM
Jhagins
Jun 21, 2012 12:51 PM
jc8825
Jul 16, 2010 02:07 PM
