Sponsored by: Real Truck
FLASHER RELAY HELP!!
Old Jul 15, 2010 | 12:43 PM
jc8825's Avatar
jc8825
My signal flasher relay just started acting up. When the ignition is in the ON position, the relay crackles and almost sounds like a buzzer. It will stop if the turn signal is switched on or if you step on the brake (illuminating the brake lights), but go right back to "buzzing" when the signal is switched off or you let off the brake pedal. No other electronic devices on the truck cause the buzzing to stop. I replaced the relay with a brand new one from Ford, and it still does the same thing. Before I go and pay someone to look at this, anyone know a solution or heard of the problem? Thanks.
Old Jul 15, 2010 | 04:06 PM
BareBones's Avatar
BareBones
Usually buzzing noises from electrical components are due to corroded terminals or contacts. Check the area closely and try to reseat any plugs or connetctors, etc. Also look for any signs of water leakage.
You need to indicate the year and model of your truck....
Old Jul 15, 2010 | 07:56 PM
jc8825's Avatar
jc8825
I checked the contacts and no corrosion. The box the relay plugs into goes directly into the wire harness, so I can't track back very far. No water leakage I can determine.
Old Jul 15, 2010 | 08:58 PM
BareBones's Avatar
BareBones
What year and type of truck. Have you recently acquired it. When the truck is running and charging, do you have about 14 volts? Any mods or security systems?
Old Jul 15, 2010 | 09:03 PM
jc8825's Avatar
jc8825
Bought it a few months ago. 2004 F-250 XLT 4x4 5.4L with the ZF. It just started. Truck is charging fine as best I can tell. No other issues. No mods or security system (heck, I leave the key in it most of the time).
Old Jul 16, 2010 | 02:07 PM
jc8825's Avatar
jc8825
Bump to the top.
1'stonraceday
18
Sep 14, 2015 08:50 AM
compwrench
1997 - 2003 F150
Jun 25, 2012 04:45 PM
ridgeseeker
May 14, 2012 06:26 PM
Hooker Bob
Mar 3, 2011 10:06 AM
bdf01f150
1997 - 2003 F150
Feb 10, 2007 07:01 PM
