If it was stuck closed I would have no power at all correct?I'm not sure how much of an opening there is when it is closed that's why I'm asking this stupid question?Thanks.
Tazz,
Two wire connector,driver's side of turbo,down low.And while I'm typing-saw your other post-yea I'd say it sounds like it's closing on ya.You must be running stock exhaust, w/open pipe it's REALLY loud when closed.
Thanks! It used to make a really loud a noise until it was warmed up, I disconnected a sensor that plugged into the stock air filter box and the noise went away. I'm not sure now what that sensor was..... I have lost it since I removed it!
