7.3 psd battery light on
Old Dec 16, 2005 | 09:46 PM
gilamountainman's Avatar
gilamountainman
Cool 7.3 psd battery light on
Yesterday I noticed that the battery light stayed on while driving to work. I then looked at the battery charge gauge and it roughly was at about 18 volts. I made it back home and didn't think anything was wrong. Today I drove my stroke around the block looking for my wife's escapee terriers and I noticed that the gauge was hovering around 10volts. I made it home and pulled out my trusty volt meter to check the batteries. Both batteries are reading about 11.8 volts. I went ahead and cleaned both cables. I started my truck back up and the battery volt cauge is still hovering around 10 volts. Anybody out there have any idea what could be causing this? also I have full power in the truck meaning my lights are perfectly bright and the stereo works just fine.
Old Dec 16, 2005 | 10:12 PM
PSNut's Avatar
PSNut
Ouch! 18volts is too high for charging. Can u verify that with a voltmeter. A good battery shows 12.5 volts alone and about 14.5 volts while engine running.
U may need a new regulator.
Old Dec 17, 2005 | 12:19 AM
Kwikkordead's Avatar
Kwikkordead
Replace your alternator before you boil your batteries dry. They are most likely suffering heavily as it is. 18 volts is WAY to high. I agree with PSnut, 14.5 max is what you should see.
Old Dec 17, 2005 | 12:20 AM
Kwikkordead
Wow, lots of new members tonight!
Welcome to the forum gilamountainman.
Old Dec 17, 2005 | 12:24 AM
empiretc's Avatar
empiretc
Yeah, alternator. Without a doubt.
Old Dec 17, 2005 | 08:19 AM
Trigger's Avatar
Trigger
I agree alternator. Just for a sanity check, measure voltage with your meter when its running.
Old Dec 17, 2005 | 09:59 AM
stroker2's Avatar
stroker2
Sounds like the voltage regulator in the alternator. If you can spare the downtime on the truck and want to save some money, take your alternator to a place/shop that rebuilds alternators, starters, etc. Have them repair it and also ask them to check it out throughly and give you a price on any improvements they can do to it. Most of those places can "bullit proof" it with better bearings, etc. If they can reasonably priced increase the output to 140-145 amps, that would also be worth it. You'll get a better alternator out of it than you will buying a re-man from some discount auto place and for alot less money.
If you can't wait on rebuilding an alternator, get at least a 130 amp output alternator. From what I've read, many places will try to sell you a 110 amp and you're better off with the 130. You don't need a 150+ amp unless your running alot of lights and add-on stuff, like an ambulance or tow truck.
Old Dec 17, 2005 | 10:14 PM
cangim's Avatar
cangim
I agree alternator as well, but I also feel inclined to mention that you can get a new 200A alternator for just over 200 bucks, there is also some 110A there as well, but I agree 110A seems small. I really like the idea of having is custom rebuilt. 150A would suit my wants perfect.
Old Dec 18, 2005 | 12:59 PM
dunbar15's Avatar
dunbar15
I had the exact same symptom, was my alternator
Good luck
Old Dec 18, 2005 | 07:15 PM
PSNut's Avatar
PSNut
Good luck
Dis u gat my PM?
Old Dec 20, 2005 | 07:25 PM
gilamountainman
battery light on
Originally Posted by PSNut
Dis u gat my PM?
Guys I had an alternator shop build me a 150 amp for the tune of $180 and replaced my cheap Walmart batteries with two Optimas. The light went back out. thanks for all the info!
Old Dec 20, 2005 | 07:55 PM
PSNut's Avatar
PSNut
Cool! Can i ask what the Optima's set u back?
Old Dec 22, 2005 | 11:37 AM
gilamountainman
Spent $130 each.
Nate38654
Aug 21, 2016 04:47 PM
1Austin112
May 10, 2016 05:11 PM
94-Beast-F350
35
Feb 3, 2016 07:52 AM
jmuenchow
Nov 18, 2015 02:18 PM
