Electrical issue
So im not sure why everything wants to decide to break lately all at the same time but another issue arose that im really stumped on. So i have 3 custom dash pod gauges ( tach, voltage, oil psi ) and sunday i noticed that my voltage and oil psi gauge weren't really working right so i thought, oil psi was at 0 and sometimes would spike back to around 20 which is normal then my voltage would be around 10-11 when normally its at 13-14. Didn't think a whole lot of it but yesterday night me and a buddy were making a midnight food run and on the way all my gauges went real dim with all my lights in the cab, he started smacking the gauges and they would all return back to normal ( tach, volts, oil ) but when he stopped beating them they all went back super dim and stopped working. We figured we would just check for a lose wire in the morning, continued on and got food, went to start the truck back and no go, battery was drained and reading 7 volts. Had someone give me a jump and it started right up. So we got in and went on our way home, but as soon as we left the parking lot my volt meter read back at 5-7, radio shut off, all gauges died, my speedometer didnt work, stayed at 0 the whole time, under it where it says your miles was blank, all my dash lights came on ( cel, airbag, battery, ect ) my tow button on the end of the gear selector was blinking, truck was a bit hesitant on going when i tried giving it gas although it still accelerated after a second of giving it gas. Woke up and ripped all my gauges out to find all wires were intact, grounds were still fine, didnt find any lose or broken wiring from radio, gauges or my amp. What really gets me is i hooked my multi meter up to the battery studs themselves without the actual terminals attached and it read 11.94 volts... i then attached the positive terminal from the truck to battery and volts stayed the same, but as soon as i attached the neg / ground terminal to the battery it instantly dropped to 7.4 volts and drops really quickly and steady until i pull that terminal back off, once its off it goes right back to 11.90-11.94 volts, then if i try putting it back on it drops again to 7.4. I've tried looking for broken or junk wiring but everything looks decent. Can anyone shed some light on why it would drop that much when the ground/neg terminal is placed on or how to go about locating and fixing this issue? Im completely lost on this one
95 f150 rwd xlt
If that's the case the battery is toast, most likely. Try a slow thorough charge for a day but if it's more than several years old it's time to shop for a replacement.
Now this may not be the source of of the problem (phantom or parasitic drain sounds like too) it may be a symptom, but a defective battery can result in some strange stuff, and damage other components too.
12.8 volts is a fully charged "maintenance free" battery at 70 degrees. Keep the battery charged up at all times till things get set right.
No, exposed ground wire or grounding to the frame won't hurt anything. There is a parasitic leak or phantom draw and need to find it or you'll be replacing batts every six months.
The way you do that is to place an ammeter in series between a battery post and cable terminal. Old school trucks should read Zero draw, more modern trucks with security systems and radio presets and bun warmers and computer whizzernangle gee-gaws have a low, constant draw.
But it should not exceed about 50 to 75 milliamperes. A 1000 mA = 1 ampere. Set up your ammeter and let the computers and such power down, maybe 45 minutes. Then check the draw. Start pulling fuses to see what's causing the draw.
Typical problem areas are rear wiper motors that won't park properly, aftermarket stereo or security or remote start systems, etc.
Modern trucks seem to draw down pretty fast even when technically nothing is wrong. They take a half hour to an hour for all the modules to "sleep", and during that time they draw the equivalent juice of leaving a headlight or two on. This puts the battery behind the eightball over time.
Modern trucks seem to draw down pretty fast even when technically nothing is wrong. They take a half hour to an hour for all the modules to "sleep", and they draw the equivalent juice of leaving a headlight or two on. This puts the battery behind the eightball over time.
