Alternator fail
Old Nov 17, 2015 | 09:06 PM
jmuenchow's Avatar
jmuenchow
Alternator fail
I got my batteries, starter and alternator checked today. Batteries and starter are good and alternator failed volt regulation (?). I replaced it and still same thing.. I have a mechanical volt gauge and at idle it is barely putting out 12-13 volts. To my understanding this should be about 14 (?). I did notice the alternator belt flaps around but I have read that it's actually normal. Is there a bad wiring somewhere? Or am I just looking at getting a warranty?
Edit: 91 f250 7.3
Old Nov 17, 2015 | 11:05 PM
Ford_Six's Avatar
Ford_Six
The voltage regulator is external, on the fenderwell or radiator support. That is probably bad.
Old Nov 17, 2015 | 11:41 PM
The_Josh_Bear's Avatar
The_Josh_Bear
X2
Voltage regulator is square boxy thing on the flat metal pan behind the passenger battery. Has 4(?) wires coming out of it.
If all you want is a regulator, upgrade to one that pumps out like 14.2v. Stock is pathetic.
I wish I could link it but another member years ago suggested that, cause he'd done it. He loved it.
I went with the 3g alternator upgrade, which moves the regulator inside(or at least on-board) with the alternator. That alt pumps out over twice the amps of the Stock unit, with light wiring involved.
There are a few good write-ups already out there, just search for them.
Old Nov 18, 2015 | 08:25 AM
jmuenchow's Avatar
jmuenchow
Originally Posted by The_Josh_Bear
X2
I got a new regulator. Is this as easy as unplug and bolt the old and and bolt and plug the new one?
Old Nov 18, 2015 | 09:07 AM
jmuenchow's Avatar
jmuenchow
when going to replace my volt. regulator i found a wire was just hanging off of the harness. i found a diagram but am unsure what or how this wire is supposed to be connected.
that is the diagram.
those are the pics of the wire on my truck. it looks to be a yellow wire.
thanks.
Old Nov 18, 2015 | 09:33 AM
The_Josh_Bear
Yup, it's literally as easy as unplug and unbolt, then bolt and plug.
Not sure about that wire, Looks like a factory terminal and has been unplugged for a long time.
Old Nov 18, 2015 | 09:40 AM
jmuenchow's Avatar
jmuenchow
On the diagram it looks like it is supposed to be connected to the alternator?
Old Nov 18, 2015 | 11:23 AM
The_Josh_Bear
Now that I zoomed in it looks like a 5th wire.
Are there 4 coming out of the plug, plus that one?
Looks like something that was intentionally left like that from the factory. I'd just run the new one and check voltage with a volt meter.
Old Nov 18, 2015 | 11:38 AM
jmuenchow's Avatar
jmuenchow
There are only 4 including that wire
Old Nov 18, 2015 | 11:39 AM
jmuenchow's Avatar
jmuenchow
Correction you are right.
Old Nov 18, 2015 | 02:11 PM
jmuenchow's Avatar
jmuenchow
FIXED
the voltage regulator fixed it for me. as you can see you could say i needed a new one, lol.
as expected my harness was toast..completely rusted so i just extending the wires a bit with butt connectors and used female end of a spade connector to connect to the spades on the voltage regulator. if you are going to do this be sure that you do one wire at a time to prevent putting the wrong wire in the wrong spot.
as always these forums have helped me fix my problem.
thank you all!!
Old Nov 18, 2015 | 02:15 PM
The_Josh_Bear
Wow that's toast! Glad you got her running good!
Old Nov 18, 2015 | 02:18 PM
jmuenchow's Avatar
jmuenchow
thank you for your help, sir.
wildwest2
Jul 30, 2018 01:52 PM
RANGER589
May 20, 2011 08:40 AM
johncardi
Jul 5, 2009 11:11 PM
jboard
Mar 12, 2006 09:07 PM
