Old Jan 3, 2002 | 10:05 PM
thewall's Avatar
thewall
Good day everyone,
I'm doing my best to dismantle my 9" rearend so that I can not only refinish it, but replace any worn out bits. I've been able to pull off the front section along with the driveshaft yoke and pinion but I am stuck trying to remove the front housing. Forgive me if my terminology isn't correct, I'm a first timer. The part I'm trying to remove has 10 nuts on studs and the lower two need a wrench to get at them. They have all been removed and the part still won't come off. I don't want to beat on it and cause damage so I'm asking what the best way of removal is. Thanks in advance.
Don W.
Old Jan 3, 2002 | 10:09 PM
85351ho's Avatar
85351ho
did you pull out your axles? if not, jack the truck up, take off the tires, pull off the brake drums, and you will find 4 nuts that hold the axle on, removie them and carefully slide the axles out, then your 3rd member should come right out
Old Jan 3, 2002 | 10:33 PM
390fe's Avatar
390fe
Chris is right. Gotta pull the axles out first!
Jason Kendrick
Old Jan 3, 2002 | 11:54 PM
thewall's Avatar
thewall
Thanks folks, I'll make sure that is my next step.
Don W.
Old Jan 4, 2002 | 07:48 AM
my275's Avatar
my275
Jeff W.
Jan 1, 2015 09:57 AM
Tony Gannon
Jan 17, 2010 04:57 PM
MattyF
1983 - 2012 Ranger & B-Series
Oct 3, 2007 08:33 PM
Fat Fendered Ford
Mar 20, 2003 05:36 PM
