Sponsored by: Real Truck
sloppy shifter, ignition switch removal
Old Jan 17, 2010 | 03:19 PM
Tony Gannon's Avatar
Tony Gannon
My shifter won't engage in any of the gears, it feels like it's disconnected.
I'm trying to get the strg. column shroud off but I don't know how to get the ignition switch off so I can remove the top part of the shroud?
Old Jan 17, 2010 | 04:56 PM
fredsheffield's Avatar
fredsheffield
Pull the covers off the bottom of the dash underneath the steering column, look back near the firewall and the cable snaps into a bracket, it probably is out of the holder, factory installs used a wire tie to secure it in the bracket. Anyway, with that bottom removed, you can see the shift cable and will be able to diagnose from there.
Old Jan 17, 2010 | 04:57 PM
fredsheffield
The ignition switch, with the bottom shroud off, look underneath the ignition switch, little tiny hole has a pin inside it, with key in accessory, you can push it in using a pick and simply pull the lock out.
timmygyu
1978 - 1996 Big Bronco
Feb 27, 2013 06:40 PM
white99
18
Sep 26, 2012 02:51 PM
pressureelite
1997 - 2003 F150
Jul 7, 2010 03:40 PM
skippr76
Feb 20, 2008 03:33 AM
ranh
Dec 7, 2006 11:14 AM
