Loose Steering
Old Dec 13, 2005 | 12:07 AM
babolton's Avatar
babolton
Loose Steering
I am fixing up my 76 custom f100 and I wanted to know if i change out the steering box will that fix my loose steering or is there another way to fix this problem
Old Dec 13, 2005 | 12:17 AM
budman-mo's Avatar
budman-mo
This would depend on IF your box is loose, could be tie rods, king pins or other suspension parts. Even rear suspension problems can make them loose on the road.
Old Dec 13, 2005 | 12:23 AM
redF-truck's Avatar
redF-truck
i would take that to church or some thing and get those low moral standards fixed. jk i bet you have some tie rods or somethig like that worn out.
Old Dec 13, 2005 | 12:28 AM
babolton's Avatar
babolton
I got under the tuck to see if the tie rods were moving but when the wheel turns at the top of the box nothing turns at the bottom of the box could this still be worn tie rods
Old Dec 13, 2005 | 12:34 AM
brown79's Avatar
brown79
okay i have a silly question are the bolts which hold the steering box to the frame tight? (seen it happen before)
Old Dec 13, 2005 | 12:36 AM
babolton's Avatar
babolton
yes i they are my brother ask the same thing he had that problem on his truck
Old Dec 13, 2005 | 01:59 PM
classic79's Avatar
classic79
do a search first, but you can adust the box to remove the slack. You said you already checked the tie rod ends. Also check the rag joint or steering coupler thats a common wear item.
Old Dec 13, 2005 | 10:50 PM
barnstormer's Avatar
barnstormer
Good call classic79.
Had the same problem with my 79 F100 and it was a bad rag joint.
Old Dec 15, 2005 | 01:18 AM
babolton's Avatar
babolton
cool thanks
Old Dec 15, 2005 | 12:03 PM
busted knuckle's Avatar
busted knuckle
not meaning to hijack here but i cant keep my ragjoint together with the shaft it just pops off = court and tickets and cost to repair fence any ideasthe bolt was replaced with the bolt in my bodylift kit when it was done any chance the bolt is the wrong size? if not where can i get a new ragjoint and what do they cost?
thanks a bunch
BN
Old Dec 16, 2005 | 09:13 PM
barnstormer
Man I feel your pain.
I think the rag joint kit includes the bolts. I got mine at O'Reilly. For about $10.00
Old Dec 17, 2005 | 08:03 AM
fordnjneer's Avatar
fordnjneer
Busted knuckle (or fence as it were) you should try to locate the original bolt that held the rag joint onto the steering box input shaft. Measure it with calipers and compare it to the one that came with this "lift kit." If the new one is smaller you should try to get a grade 8 equivalent bolt from a hardware or auto parts store. Another thing you can do (if you have a telescoping shaft) is to put some kind of clamp on the shaft where the smaller section can retract into the larger. Put the clamp in a position only slightly past where the smaller shaft goes indside the larger. This will prevent the shaft from retracting and will not allow the rag joint to come off. Either way, you should feel the steering getting loose well before you destroy any neighbors yards.
Explorer Freak
May 24, 2010 10:19 PM
Mustangfreak
May 13, 2009 08:01 AM
Robbgt
18
Mar 13, 2008 08:14 AM
chumpchange
Aug 5, 2006 04:07 PM
joseph_m48075
Nov 5, 2003 01:34 AM
