79 4x4 crewcab frontaxle?
Old Dec 15, 2005 | 05:07 PM
marcs724's Avatar
marcs724
Does anyone know if the front axle under a 79 F250 4x4 crew cab is a 44 or a 60? I have pictures of the one I'm trying to get, but I can't see the spindles, and can't really tell how big the hubs are. It does have a sway bar on it, and the fender of the truck has a badge of some sorts, in the spot where I've seen other trucks say camper special... but i can't make out what the badge says. Any ideas?? Also, any idea how many of these were made in 79?
Old Dec 15, 2005 | 05:23 PM
ivanribic's Avatar
ivanribic
Easiest way to tell: Look at the top of the knuckles. If they have kingpins with 4 bolts in a square pattern that hold the cap in place (and on the driver's side hold the steering arm in place) then it's a D60. If they have 1 fat nut up top there or 3 bolts in an arc then it's a D44.
Old Dec 15, 2005 | 05:25 PM
MBBFord's Avatar
MBBFord
I'm pretty sure it's a HD44, but if it is a camper special, or somthing of that sort, I don't remember which package got you a D60.
Old Dec 16, 2005 | 01:06 PM
Slow's Avatar
Slow
I'm not sure what option or whatever caused a D60 to go into a crew cab, but of the 3 I own, 2 have D60s while one has a 44 (unfotunately the 79!), so I'd say your odds are like 50:50. Cap'n crunches suggestion is good.. another way to tell is to take a wire brush under there and clean off the casting around where the front cover goes on along the bottom.. somewhere on there will be a "44" or a "60" cast into it.
Once you've seen a few you can tell just by looking at the hubs.
Old Dec 16, 2005 | 04:16 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
The D60s came as part of the "Snow Fighter" package. For snow plows and such.
Old Dec 17, 2005 | 08:07 AM
MBBFord's Avatar
MBBFord
That's what it was. Thanks for clarifiying that FordTruckKickGM.
