Too Big Carb ?
Old Dec 11, 2005 | 06:11 PM
blieux1's Avatar
blieux1
Too Big Carb ?
I have a 79 F100 with a 351W motor and a Holly 600CFM . Keep fouling out plugs and contant black smoke out tail pipes .I have tried adjusting carb but does not help. Is the 600 too big for my motor ? Its a stock remanufactured motor from Advance Auto Parts.
Old Dec 11, 2005 | 06:16 PM
User 71024's Avatar
User 71024
I have an edlebrock 600 on my 70 stang with a windsor and it runs fine, are you sure your choke is operating properly?
the formula for CFM needed is RPM X CID/3456
Old Dec 11, 2005 | 06:35 PM
satx77stepside's Avatar
satx77stepside
600 is not too big.
Couple of questions on your post though.
It's a 351W or did you mean 351M?
Also, where did you get this carb? How old is it? How long was it left sitting?
What intake are you using? I'm pretty sure the only engine w/ a 4 bbl intake was the 460. Do you have a 4 bbl intake or are you using one of those god awefull adaptor plates?
Old Dec 11, 2005 | 07:28 PM
derherr65's Avatar
derherr65
If you had a carb that was too big it would have low air velocity in the venturi, draw very little fuel, and run lean. At higher rpm it might be OK. Naturally if you rejetted it richer you could get it to run OK at low rpm, but the it would run rich at high rpm. It would have horrible throttle responce in either case. A 600 is not too big for a 351. I ran a 600 on my mild 289 and it wouldn't bog unless I floored it below 1200rpm.
Most likely you have choke problems, a internal carb leak(floats too high?), wrong jetting, a stuck something or other(secondaries partly open?), or your plug fouling is oil not gas.
Old Dec 11, 2005 | 10:22 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
yes, tell us about this carb....could anyone have messed with the jetting??
power valve ok?
Old Dec 12, 2005 | 12:20 AM
blieux1's Avatar
blieux1
I bought the carb new from advanced auto parts. It is a 351w motor. I have an Elderblock aluminum intake. The only adjustment I've done is wiyh the screw on the front metering block everything else is factory set.
Old Dec 12, 2005 | 03:55 AM
KubotaOrange76
vaccum secondaries?
Old Dec 12, 2005 | 04:13 AM
blieux1's Avatar
blieux1
yes it has vaccum secondaries and electric choke. Everyone that i talked to and showed the plugs to said that is was running to rich and that is why the plugs were fouling and looked black and sooty.
Old Dec 12, 2005 | 08:16 AM
derherr65's Avatar
derherr65
When the engine is warm does the choke plate point straight up and down? If not your choke is still on and this will make you run rich all the time.
pittmick
Jan 20, 2010 04:06 PM
jdog34436
Nov 27, 2005 01:07 PM
youngguy
15
Mar 15, 2004 10:09 AM
78bigblock
May 25, 2002 04:14 PM
007truck
Dec 14, 2001 08:39 PM
