shimming the pump
Old Dec 10, 2005 | 12:37 AM
devilsword's Avatar
devilsword
Lightbulb shimming the pump
i heard that drag racers and a few people put a shim in the oil pum p to increase pressure and flow. has anyone done this i have a 87 2.9 ranger and i heard its a simple task. pros cons tec. help would be wounderful.
Old Dec 10, 2005 | 04:57 PM
probedude's Avatar
probedude
You shim the spring on the pressure regulator built into the pump- effectively making this spring stronger and boosting the oil pressure.
There's curves for pressure vs flow - more pressure does equal more flow but you can also wear out the oil pump faster and more pressure if you don't need it won't do anything.
Old Dec 10, 2005 | 08:06 PM
RangerPilot's Avatar
RangerPilot
What would you use an '87 2.9L for that possibly needs more oil flow? I would call the oil flow pretty good in that engine.
It's the 4.0L that needs more upper oiling power. eh...
Old Dec 11, 2005 | 12:43 AM
devilsword's Avatar
devilsword
well i was thinking that i can use the incress flow to warm up the truck alot quicker in the winter here. i live in va so we have harsh summers and bitter winters. so i was thinking about a oil cooler but in the winter it woulod be like pumping a brick for a hour.
Old Dec 11, 2005 | 09:58 AM
frankenbroncoII's Avatar
frankenbroncoII
my 86 2.9 with the original oil pump starts up with 40psi oil pressure and 30 psi when warm. its not a h.o. engine why would u need to boost the factory pump?
Old Dec 11, 2005 | 12:00 PM
Dave257's Avatar
Dave257
The reason most racers shim the oil pump is because the engines have looser clearences on the bearings. Looser clearences mean less friction and more power, however it also allows oil to flow past the bearings and hence the need for more pressure. At one time the thinking was lower pressure (it takes power to drive the pump to higher pressures) and more flow. So pumps were "ported" to flow more and lower pressure to gain power.
If you are having heating trouble that is a different matter. You may want to check to see if someone put a lower temp thermostat in the truck.(bad idea)
Dave
Old Dec 12, 2005 | 01:53 AM
devilsword's Avatar
devilsword
no i placed a new 195 for the winter in about a week ago. But the friction is a worry. i am starting nagotiation again about getting my ranger sponsered again for shows. And one of the companys that i was going to sign with(before my accident) is opening talk up again with me and offering 50% to 75% on my choice of costom supercharge or turbo for my 2.9. So i am really excited again to look over the terms of contract. But i want to do all possible to avoid and problem since it will be my show and street truck.
pilgrimbizket
22
Feb 17, 2015 09:26 AM
lilrobo
May 3, 2014 08:32 PM
fordeverpower
13
Jul 24, 2008 01:25 PM
samahi72
Jan 26, 2005 08:44 PM
hillbillyk
Feb 6, 2001 08:34 PM
