Sponsored by: Real Truck
Rear brakes
Old Dec 8, 2005 | 06:05 PM
Shade guy's Avatar
Shade guy
Rear brakes
99 f-250 with disc brakes on the rear and it seems to me that the caliper pin on the bottom is stuck the one on the top slides in and out and will spin the one on bottom is stuck is this normal?
Old Dec 8, 2005 | 07:10 PM
tjbeggs's Avatar
tjbeggs
normal no .... common yes very common. the rubber boot is either ripped or just didn't keep the junk out and so the pin seizes in there. fronts also have this problem. you will need to take the brakes apart and get the pad anchor (the piece the pin is in) out and you may be able to soak it in wd-40 or other penatrating oil then wiggle it out but at work i usually have to heat it with a torch. but be careful as in the sheet metal 12 foot ceiling of our shop there is a hole right above the vise where we heated the anchor and the pin shot out like a bullet and made a hole in the ceiling.
so anyway you will need to get new rubber boot from the parts store. and hope it will come out. it will but it may take some work.
Old Dec 8, 2005 | 08:45 PM
99f350sd's Avatar
99f350sd
Use a good brake greese when you put it all together.
Old Dec 8, 2005 | 09:15 PM
Shade guy's Avatar
Shade guy
Ok thanks for the help
Old Dec 9, 2005 | 11:50 AM
tjbeggs's Avatar
tjbeggs
yep forgot that part!!!
inthewindmom
Oct 28, 2013 05:35 PM
78ford351m
18
Jul 29, 2010 08:32 AM
deercreek1
Jul 10, 2010 06:26 PM
VIKING24
Jun 14, 2005 07:31 PM
