Tire Help
Old Dec 13, 2005 | 03:49 PM
  #31
ZBeeble's Avatar
ZBeeble
I'm nearly positive that pressure and load weight arn't going to be a linear relationship.
First of all, below a certain pressure (15 lbs or so?), the bead breaks ... so there's a step function.
Secondly, the pressure (in lbs/sq in) is multiplied by the "sq in" in question (the contact patch)
And thirdly, the sidewall of the tire has some effect, although it likely depends on the tire.
All this is to say that the effective range of the estimate is limited.
Old Dec 15, 2005 | 06:34 AM
  #32
Fords4Me's Avatar
Fords4Me
I'm not trying to start a big debate ZBeeble, but with the stock tire being rated @ 3085/80, at 15 pounds the load should be 578#, the X is a little more than 2300#. I do belive you are correct about it not being completely linear, but it isn't completely wrong either. Maybe subtract the 15# first, do the math, and then add it back in?
There's gotta be a way.
F250xlt2005
2009 - 2014 F150
Dec 7, 2011 03:05 PM
4getfulbj
2004 - 2008 F150
Apr 23, 2007 03:51 PM
yabohd528
1983 - 2012 Ranger & B-Series
Nov 3, 2006 01:19 PM
froste
2004 - 2008 F150
Jun 9, 2004 12:03 PM
69BRONCO
1966 - 1977 Early Broncos
Mar 14, 2002 01:45 PM
