Offroad & 4x4
ARB's rock!
Old Dec 6, 2005 | 12:58 PM
  #31
fishmanndotcom's Avatar
fishmanndotcom
or you could just lug around one of the big tanks
-cutts-
Old Dec 6, 2005 | 01:11 PM
  #32
ivanribic's Avatar
ivanribic
I think he's talking if you have one of the big **** tanks you could use it to fill the 20lb tanks but you're not really saving any $$, just saving a couple trips to the gas shop. Mine is about a mile from me so it's no big deal. KO, do you use any kind of special regulator or could I use the regulator I'm using for my welder?
Old Dec 6, 2005 | 01:30 PM
  #33
proeliator's Avatar
proeliator
You can pick up the fittings you need to make it work for cheap at most paintball supply places.
Old Dec 6, 2005 | 03:34 PM
  #34
chrono4's Avatar
chrono4
the guys that ive seen that are big into it get the big ole' full siz bottles to do it.
Old Dec 6, 2005 | 05:48 PM
  #35
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
ohh ok, cool, ive seen guys using 10-40 lb bottles for it as well
here ivan....these are the folks i got all my junk besides the tank from
http://www.offroadair.net/products2.html
this is the reg i run....i got it because it wont freeze, and it flows some serious air, and the gauge is a nice peice too...its an oil filled gauge that goes from 0-600...i woulda went with the 150psi fixed regulator...but i wanted to be able to adjust the output to use whatever i needed. because this is my onlny source of compressed air down here at school
i also bought their mounting bracket because its a high quality peice and it works good...it hasd a place for a padlock as well
i did a ton of research before i bought my setup...and i was tempted to just get a regulat welding regulator....but i saw thatwhen the ice that forms on them, that it tends to screw up the diaprams inside. also they dont flow as much as these regulators do
Old Dec 6, 2005 | 10:49 PM
  #36
mustange70's Avatar
mustange70
most do, but some have pretty big tanks too i've seen 50lb+ tanks in a number of places.
Old Dec 24, 2005 | 06:56 PM
  #37
rebocardo's Avatar
rebocardo
I saw a F-150 with all sorts of decals for VMAC and how it was equipped with a 150 CFM air compressor!
So, I decided to check the web site listed on the truck:
www.underhoodair.com
Just posted it here instead of starting a topic for one web site.
Old Dec 24, 2005 | 07:07 PM
  #38
chrono4's Avatar
chrono4
wow. thast alot of air.
Old Dec 24, 2005 | 09:58 PM
  #39
KubotaOrange76
how much $$$$$$$$$$?
Old Dec 24, 2005 | 11:22 PM
  #40
chrono4's Avatar
chrono4
thats what i wanna know, man that would be a big improvement over the york.
Old Dec 26, 2005 | 04:12 PM
  #41
rebocardo's Avatar
rebocardo
Yea, looks like a dist. only thing. The only thing I do not like is it automatically releases tank pressure with the vehicle off, though that could be overcome with a switch I imagine.
Old Dec 26, 2005 | 05:46 PM
  #42
ivanribic's Avatar
ivanribic
All this should take to fix is a check valve between the compressor and tank.
Old Jan 5, 2006 | 11:11 AM
  #43
74 F100 351m's Avatar
74 F100 351m
Ivan I see you got it muddy. How did it work? I was looking at your crossover steering. I am trying to do the same with my F250 with a D44. I have 11-12" of lift.
Old Jan 5, 2006 | 11:16 AM
  #44
ivanribic's Avatar
ivanribic
Everything worked awesome, infact I'll start a seperate thread about it here in the offroad forum.
Blapensee
6.7L Power Stroke Diesel
Feb 4, 2015 08:51 PM
77-250
Aug 22, 2010 02:28 PM
FordTrucksKickGM
Jun 14, 2007 09:59 AM
mizzitch
Dec 9, 2004 10:53 AM
BigSix1
Garage & Workshop
Jan 5, 2004 02:26 AM
