Omg!!!!!!!!!!!!
Old Dec 5, 2005 | 09:50 AM
  #61
GaCracker's Avatar
GaCracker
4th Gear
I hate to sound <read> like the total noob but, with this chip, can I remove it easily before taking the truck in for service? I hate the thought of wasting that $ I spent on an extended bumper to bumper warranty.
Old Dec 5, 2005 | 10:48 AM
  #62
Fordafied's Avatar
Fordafied
You can remove it easily, but the dealer will still know there has been a chip installed in the past. It will leave a code and they will see the plug gone and the connectors cleaned.
Old Dec 5, 2005 | 05:44 PM
  #63
PowerStrokeMe's Avatar
PowerStrokeMe
I heard the TS Perf 6 pos chip doesnt leave that code
Old Dec 5, 2005 | 06:09 PM
  #64
Fire Rooster's Avatar
Fire Rooster
They all leave a traceable code or routing #. So do tuners so all of you cheaters quit fooling yourselves. If the Ford Corp. really wants to void your warranty they will, chip, tuner or otherwise.
  #65
nodoubt's Avatar
nodoubt
.....any chip will.....thats the ONLY place a programmer will out shine a chip...........
Old Dec 5, 2005 | 06:42 PM
  #66
johnny8's Avatar
johnny8
trust me when i tell you, they don't need the excuse of a chip or a tuner, they can deny your claim for no reason at all.... personally i don't think that most of these warranties are worth the paper they are printed on... take the ball joints for example... they are junk right from the factory... if you sqwak and yell and scream because your original set of ball joints didn't last 25k miles they might replace them for you, but they will put the same JUNK right back in your truck... useless... the ONLY time they fix something right is when lawsuits have been or could be involved and the manufacturer does a recall... sorry guys but them's the plain facts...
Old Dec 5, 2005 | 08:02 PM
  #67
Fordafied's Avatar
Fordafied
Hate to burst your bubble, but a programmer also leaves a code that you can not get rid of even if you unhook the batteries.
Old Dec 5, 2005 | 08:32 PM
  #68
WA.Ranger's Avatar
WA.Ranger
Doesn't it also leave a way bigger spray pattern on top of the pistons?
Old Dec 5, 2005 | 08:38 PM
  #69
Fordafied's Avatar
Fordafied
Absolutely, there was a thread on here or somewhere I saw, that had pictures of the piston tops and you could definitely tell a difference in the one that had been "hopped up" and one that was stock. Great comparison.
Old Dec 6, 2005 | 09:15 AM
  #70
EDMGUY69's Avatar
EDMGUY69
Now here is the bad news, pretty unrelated but crappy non the less. I get home from the fire station today to find out the water main to my house has ruptured. It is gonna cost me 7500.00 bones to fix. Spent all day today digging up my drive way. Sure felt good to get in my truck and drive to the local eatery though.
Got any LDH laying around that the Chief would let you have for a while??
That sucks.
Old Dec 6, 2005 | 11:04 AM
  #71
1997F-350's Avatar
1997F-350
Originally Posted by Fat Diesel
Au Contraire Monfrere. My HPOP PSI drops to 1900 on my highest chip setting (100 HP DP Tuner) and for sure needs more pressure to get anywhere near the performance it can offer. I have early 99 AB injectors that are actually "smaller" than the later 99.5+. There are several companies offering modified single and some dual pumps that can maintain 3000+. The latest discussions have indicated that "big oil" gives as much power increase as Stage I injectors.
you have the 15* degree pump and its weak i bet. buy a new pump and you will have no problems up until about stage 2's.
Old Dec 6, 2005 | 11:19 AM
  #72
Fat Diesel's Avatar
Fat Diesel
I will have less problems for sure. I most certainly have the 15 degree swash plate and a newer 17* would help. But, there is a difference between "no problems" and "optimal" for sure. I'd just prefer to buy a pump that I can grow into as long as it has a super long lifespan. I plan on driving the truck a long time and eventually build a motor with aftermarket rods, head studs, big turbo, big injectors, etc.
Old Dec 6, 2005 | 12:25 PM
  #73
Fordafied's Avatar
Fordafied
If you go to DI and look-up the Mini Me's which is some of the baddest injectors, you see they state you can run them on a stock HPOP. That is a 2000 model. If you upgrade to a 2000 model, you will be OK. That is how I knew a stock HPOP was plenty sufficient. That is way more than your chip will ever need.
Old Dec 6, 2005 | 12:56 PM
  #74
Kwikkordead's Avatar
Kwikkordead
Hmmm, I have the late '99. Does that still have the 15 degree pump? Is there a part number that I can look at?
Old Dec 6, 2005 | 01:11 PM
  #75
Fat Diesel's Avatar
Fat Diesel
Fordafied- I'm sure Mini Me's "can" be run with stock HPOP's. I don't doubt that for a minute as long as you're getting 2700psi+ at WOT. I just believe the growing number of guys who say that "BIG OIL" is like getting injectors. We're talking close to 400 rear wheel horsies out of stock AD injectors. If the stock HPOP is so effective why are three companies going into commercial production of the $2000 big oil pumps? Answer: because they work. I just don't want to pony up and pay 400+ for something that I will want to later swap out. Just my preference.
KWIK- I've read that the 15* pumps have a flat stamped steel cover on the back, while the 17* has a bulge. Others stated that is not definitive. I don't have PN's, sorry. If you can monitor HPOP and IPR DUTY then just make sure the duty on the IPR stays below say 40 and the HPOP is above 2500. From what I've read, 3000+ is optimal, 2700 is good, 2500 is poor, and everything below is totally undesirable from a performance standpoint.
