Abs
Old Nov 30, 2005 | 03:28 PM
rangerguy52's Avatar
rangerguy52
Exclamation Abs
My ABS light has been on for sometime now, yesterday I decided to stop into the dealership I work at part time to use their computer to read the codes and I got two codes:
1) C1230 - RA Wheel Speed Sensor Input Circuit Failure
2) C1229 - RA Wheel Speed Sensor Coherency Fault
I looked up the codes in my Chilton's manual. I was wondering if I replaced the rear axle wheel speed sensor ($9.99 at Car Quest) would that fix the problem?
Old Nov 30, 2005 | 11:30 PM
Jharger's Avatar
Jharger
Yup - or just clean them. they get loaded up with metalic flakes. Which also is a good indicator you should change the diff fluid.
Old Dec 3, 2005 | 10:37 PM
rangerguy52
i put a new sensor in and it cleared the C1229 code and the other is still there. the gear oil on the old sensor smelt burnt. what else could it be
Old Dec 5, 2005 | 09:50 AM
Jharger's Avatar
Jharger
Did you disconnect the battery to clear the codes out? If the ABS light is out, the code might have been left in memory.
Old Dec 5, 2005 | 12:17 PM
rangerguy52
I didnt disconnect the battery, but I did use the computer at work to clear the codes out of the abs computer, the C1229 cleared out but the C1230 code stayed on. I beleave I should change the diff oil seems how it smelt brunt and the is over a 140K miles on the explorer.
Old Dec 5, 2005 | 10:05 PM
Jharger's Avatar
Jharger
Try that but you may need a completely new sensor too.
Old Dec 6, 2005 | 07:01 AM
rangerguy52
I did replaced the sensor already, that cleared the C1229 code. The C1230 code is still there. I'll try replacing the diff oil and see what happenes.
Old Dec 6, 2005 | 07:57 AM
FortyFords's Avatar
FortyFords
Chk the connection sometimes the pins get corosion on them or push out and nolonger make contact.
We have also seen the abs module go bad.Do a test unplug the sensor and see if the 1229 comes back.
Rich
Old Dec 7, 2005 | 12:07 PM
rangerguy52
I'll try both of those and see what happenes. Thanks for the advice.
Old Dec 8, 2005 | 09:02 AM
the_merlin's Avatar
the_merlin
Update?
Please provide an update as I am experiencing the same issue.
Jeff and Nicolle
41
Jan 8, 2013 09:57 PM
Superduty21
Sep 17, 2012 08:53 AM
phadams
1997 - 2003 F150
Aug 20, 2009 09:16 PM
njxlt
Mar 28, 2009 01:52 PM
pdqtimetrialer
Oct 23, 2006 11:12 AM
