engine just dies..
Old Feb 4, 2002 | 03:46 PM
xavetarx's Avatar
xavetarx
engine just dies..
I've been tinkering on and off for a while now and can't seem to diagnose why my truck just cuts out. The engine runs perfectly until a time where it just cuts out. Not a sputtering death mind you (that's why I assume it's electrical). I've replaced the coil, ignition, coil-to-distributor wire and checked all the wire connections for shorts. Nothing. Doesn't matter how long the engines' been running or how warm/cold it is. All the grounds seem to be clean (I replaced a lot of parts recently) I'm going to inspect the ignition switch closer even though it was replaced just over a year ago. It's a 73 460. Any ideas?
Bob Weaver
Phila PA
a couple 79 Bronco's
http://members.home.net/xavetarx/79BroncoForSale.html
Old Feb 4, 2002 | 05:52 PM
Chuck P.'s Avatar
Chuck P.
engine just dies..
If it has the regulator on the pass. side fender (3" or so squarish box with 3 or 4 wires on a flat plug into it around the starter seloniod), might be worth a shot, not that expensive, 10-12 bucks last time I got one and if not, you always have it for a spare. These have been known to do funny things when going bad, but may come back and be just fine after sitting a while. When one went on me, it would only idle at 3-400 rpms and wouldn't take any kind of pedal. Shut it off, restart, run just fine, lived with this for 3 months while it got worse, before I got to the point that this was all that was left to change, and it worked! Of course didn't have these great boards to help out back then! Hope it's this simple!
Old Feb 4, 2002 | 09:12 PM
sparky's Avatar
sparky
engine just dies..
Can you start it right back up again? Is there fuel in the carb? Have you checked for spark after it has died?
Sparky
Old Feb 4, 2002 | 10:06 PM
azronster's Avatar
azronster
engine just dies..
its your ecm its a metal box on the left sided fenderwell. my truck did the same thing until i finally replaced that part. its never done it since!!
Old Feb 5, 2002 | 01:41 AM
tetraruby's Avatar
tetraruby
engine just dies..
Sparky, you made the 73+ split
Glad you're with us....
Old Feb 5, 2002 | 02:52 AM
karljay's Avatar
karljay
engine just dies..
I agree with the volt reg box, mine did the same thing and it was a bad box. Sometimes a ground will cut in and out because of rust. If not, when it dies, check for 12volts at the ign, fuse box etc...
Old Feb 5, 2002 | 09:06 AM
xavetarx's Avatar
xavetarx
engine just dies..
I'll have to check the box. Thanks for the ideas. The grounds didn't seem to be the problem a couple days ago, but I might have skipped one. Have to double check'm too.
Thanks again,
Bob Weaver
Phila PA
Old Feb 5, 2002 | 10:00 PM
sparky's Avatar
sparky
engine just dies..
Thanks, I am still "lurking around", just got more forums to "lurk" in now
Sparly
Old Feb 6, 2002 | 08:23 PM
TMancil's Avatar
TMancil
engine just dies..
Mine has just died a couple of times like that, both times when I had been sitting still and started to move. After a minute or two of trying, it would crank and run just fine.:-X23
Old Feb 6, 2002 | 08:41 PM
76RangerXLT's Avatar
76RangerXLT
engine just dies..
truckdog62563
23
Aug 16, 2010 11:27 AM
weaver79
Jan 7, 2003 07:29 PM
xavetarx
Feb 10, 2002 12:28 PM
xavetarx
Feb 6, 2002 07:59 PM
xavetarx
1978 - 1996 Big Bronco
Mar 20, 2001 07:55 PM
