decode guru?
Old Nov 29, 2005 | 02:26 PM
LowKat's Avatar
LowKat
decode guru?
Aluminium tag on door reads:
serial # F26CK123469
WB: 120
model: f262
trans: FB
axle: 24 (4?? messed up a little)
GVW 6600 ...obvious
HP: 135 ...obvious
RPM 3800...obvious
DS?: 3124
Tag is on a longbed 60's 4X4 V8 parts truck I just bought.
Found this forum while looking for axle info. Making a 'mudder' truck out of a Chevy S10 but need 'extra beef' so will be using the Dana 60 rear out of the Ford because of the narrow width.
Also cannibalizing the closed knuckle front Dana 44 for the matching 4:56 gears to put in a disc brake Jeep Wagoneer housing with Dodge 3/4 ton outers.
Using a 205 divorced t-case out of a 70's Ford 3/4 ton.
Lots of my Chevy friends are flaming me...... so feel free...
It's gonna be a real Frankenstien
Old Nov 29, 2005 | 03:16 PM
subford's Avatar
subford
F26 = F-250 4x4
C = 8 Cyl. 330 CDI 2V MD
K = Kansas City
123469 = Consecutive unit number
WB: 120 = 120 inches hub to hub
model: f262 = F-250 4x4 7,700 GVW Rating
trans: FB
In 1968 the F was an 4 -Speed Warner T-18 and B was an 10-Speed Fuller R-96 Direct. But there was not a FB code.
axle: 24 (4?? messed up a little) 24 = Dana #60 4.10:1 - 5,200 lb
Old Nov 29, 2005 | 03:43 PM
LowKat's Avatar
LowKat
330" motor? I thought Y-blocks were 292 or 312?
has a 2bbl Y-block in it
do you know what the MD designation is for the engine?
It is 'FB' for the trans code. It is a 4 speed
Old Nov 29, 2005 | 08:26 PM
61ford's Avatar
61ford
i think what he means is that the 330 was stock
Old Nov 29, 2005 | 08:30 PM
LowKat's Avatar
LowKat
OK, I'm pretty much an idiot when it comes to Ford motors. Is the 330 a member of the FE or Y-block family
Old Nov 29, 2005 | 09:05 PM
61ford's Avatar
61ford
not member of y block family y blocks are 239,272,292,312,317,341 and 368 someone else will have to chime in on the 330
Old Nov 29, 2005 | 10:00 PM
BobbyFord's Avatar
BobbyFord
Far as I know "C" for 1960 = 292, 2V, 135HP
Truck was built Dec. '60 according to the consecutive #
Old Nov 30, 2005 | 03:21 AM
Sam_Fear's Avatar
Sam_Fear
Which would classify it as a 61. And by my 61 book, the f262 is rated at 6,600 gvw - which matches your tag. 292 2v MD - has two wing nuts in centers of valve covers, dizzy in the back, and a crossover pipe across the front connecting the manifolds.
Trans - F is a T-98A Warner 4-sp - 1st is a granny gear. B might be the front axle code b=4.55 ? 24 Rear Axle code = 4.56 ratio.
Old Nov 30, 2005 | 11:25 PM
GregTruck's Avatar
GregTruck
Nobody ever said what block type (family) this 330 engine falls in. I would like to know myself. I can't find any reference to one in my V.I.N. decoder.
Old Dec 1, 2005 | 03:00 AM
Sam_Fear's Avatar
Sam_Fear
This might help:
http://www.mustangandfords.com/techarticles/15999/
Old Dec 1, 2005 | 08:15 AM
LowKat's Avatar
LowKat
Thanks for the engine info!
Old Dec 2, 2005 | 12:11 AM
GregTruck's Avatar
GregTruck
Thanks for that great link Sam Fear. I had to bookmark that one. This is a MUST read article if you are any kind of Ford big iron fan.
Check it out!!
Old Dec 2, 2005 | 01:00 PM
Mike G's Avatar
Mike G
The 330 is usually the "Medium Duty" FT engine, a relative of the FE found a lot in larger trucks or things like a U-Haul.
--Mike
hasteranger
Jun 27, 2010 10:55 PM
Lee250
Jun 14, 2007 09:36 PM
jimbo beam
General Automotive Discussion
May 8, 2006 10:45 AM
nick
Offroad & 4x4
17
Apr 12, 2004 11:15 PM
willowbilly3
Oct 23, 2003 01:35 AM
