General Automotive Discussion
? about a chevy rearend
Old May 7, 2006 | 03:14 PM
jimbo beam's Avatar
jimbo beam
hey guys, we are about to start scraping out my dads old 75 custom delux 3/4 ton.
i was looking under the truck at the rearend, at least the part that hasnt sunk into the ground, i believe it looks like a dana 60.
my question is could a 1975 chevy truck be bought with a dana 60 rearend?
If it matters the truck is a 3/4 ton custom delux, 2wd, with a granny 4 speed, and a 350 v8.
if this is indeed a dana then its going to be going under my 82 f100.
Old May 7, 2006 | 09:06 PM
10MPG's Avatar
10MPG
It's probably a low gear too,4.56's were common in those.
Old May 8, 2006 | 01:05 AM
polarbear's Avatar
polarbear
Could be- if it had the heavy GVW Pkg. In the glovebox,there should still be the tags for the build code on a plastic sheet
axle code:
GT4= 3.73
GT5= 4.10
HC4= 4.56
G80= Locking Diff
Old May 8, 2006 | 01:21 AM
ford390gashog's Avatar
ford390gashog
a d60 was standard the most common gear ratio was 3.73
Old May 8, 2006 | 10:45 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
ill bet its a 14 bolt, 10.5" ring gear, 1.5" 30 spline axle shaft....very stout rear axle...
heres a good axle id chart..http://www.coloradok5.com/axleguide.shtml
does the cover look like this?
Skip1970
Oct 27, 2013 04:02 PM
okie72
Mar 23, 2013 09:37 PM
jmstrickland
26
Dec 24, 2010 07:43 AM
Lee250
Jun 14, 2007 09:36 PM
Moose_God
1997 - 2003 F150
Sep 17, 2005 08:47 AM
