KOEO Test codes
I just pulled some codes from my truck as every once and awhile the CEL comes on then goes off. No rhyme or reason for it coming or going as far a s driving conditions go.
So I turned on the key, heard the fuel pump prime, then shut off, saw the light flicker, then started writing the codes. Here's what i recorded in short hand:
1 = blink
. = pause
11.1.11.1111.11.1.11.1111.1.111.1.1111.1.1111.1.11 11.1
From what i can understand the codes i am getting are as follows:
21,24,21,24,13,14,14,14
I'm assuming the doubles are repeats, and the 2nd to last code i messed up recording on.
21 = ECT out of self test range 0.3 to 3.7 volts.
This makes sense because the truck hasn't been started since last night and it is very cold out. I shouldn't worry about that right?
24 = ACT sensor out of self test range 0.3 to 3.7 volts.
Same as above, no reason to worry correct??
13 = Cannot control RPM during ER Self-Test low RPM check.
I didn't have the engine running so???
14 = Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall.
This one is from Continues Memory according to the site, so I'm assuming it was stored from previously. I haven't had any problems with the trucks running or misfiring.
I followed the instructions of fordfuelinjection.com for the KOEO test.
This is my first time pulling coeds so if you could help me understand them that would be great.
BTW, the truck runs fine, i just was curious if there were any codes.
Thanks,
Mike
If the truck runs fine I wouldnt worry about there being codes in the computer. Do me and yourself a favor. Take the negative battery cable off the battery and let it sit for 15 minutes or a half hour. Hook it all back up and take it for a drive for about 15 minutes so that the computer can relearn the engines actions. Then do the test again.
As to your answer about code 21, That refers to your engine coolant temp sensor. I dont think thats anything to worry about unless you have a CEL.
Code 24 is Air Charge temp sensor. Again, nothing really to worry about I dont think if there is no CEL light.
Code 13 is nothing to worry about, since its only valid under KOER (Key off engine running)
Code 14 kinda bothers me. The only thing I can come up with off the top of my head is that maybe a crank sensor (if your engine has one, which Im sure it does. Im having a dumb attack) has failed previously.
I forgot to mention earlier that you can run a test with the engine running. I believe it also tells you how to in fordfuelinjection.com. Just make sure its warm, and after a couple blinks, goose the throttle real quick and turn the wheel a half turn or so.
Hopefully I've helped you a little bit! If not then sorry!
lol
