koeo codes
23-tp sensor out of self test range. Buy new one ?
85-canister purge solenoid circuit failure. Frayed or broke wires, i took a pic, will upload shortly
koer codes
21-ect out of self test range 0.3 to 3.7 volts. Buy new one ?
23-Closed throttle TPS voltage higher or lower than expected. Buy tester an realign it ?
41-No HEGO switching detected always lean (right side). Make sure theres no split wires, especialy ground to head ?
33-EGR valve opening not detected. ??
13-Cannot control RPM during ER Self-Test low RPM check. See code 23 ?
Can you back out a little on the photos, I can not see where you are.
For the 5VDC test put your red (+) probe on any of the red X points and the black (-) probe on any of the purple X points in the diagram below and turn on the key:
I do not think you had an electrical error code for the EVR and the EVR is what is in the photos.
If you have a bad wire going to the EVP then yes it could cause the error code as you did have an error in that electrical test.
But the EVP has a Orange wire with a white stripe for 5VDC power, Black wire with a white stripe for ground return and a Brown wire with a light green stripe for its information return to pin #27 of the computer.
I think you are getting the EVR solenoid & the EVP sensor mixed up.
