Heater Hose routing
Old Nov 26, 2005 | 09:58 AM
OzarksFord's Avatar
OzarksFord
Question Heater Hose routing
I replaced the heater hoses on my 1983 Ford F150 (300 I-6 engine). I'm not sure if I replaced them correctly. The hoses coming from the heater core are side by side (one on the left, one on the right). One goes to the water pump and one goes to a fitting coming from the thermostat housing.
Which goes where? Coming from the heater core, left goes to ???? Right goes to ???? Any help would be appreciated. Thanks!
Old Nov 26, 2005 | 10:44 AM
FordF150Fixer's Avatar
FordF150Fixer
The heater core bib closest to the engine is the input and the hose on that bib should go to the thermostat housing. The bib farthest from the engine is the heater core output and its hose should go to the water pump.
Old Nov 26, 2005 | 11:41 AM
OzarksFord's Avatar
OzarksFord
Smile
Thank you! Problem fixed. I just called my brother-in-law. I remembered that he has a '78 Ford F150 with 300 I-6. He was able to verify the routing also. Glad this forum is around though!
91 Dually
Jul 30, 2015 06:49 AM
66 ford lover
Apr 27, 2012 01:10 AM
scurbiedog
1978 - 1996 Big Bronco
Jan 26, 2007 02:41 PM
rockyrider
20
May 19, 2005 09:52 PM
97ExpySC
Jul 26, 2003 11:56 PM
