Heater Core Inlet
Old May 10, 2005 | 11:37 PM
rockyrider's Avatar
rockyrider
Heater Core Inlet
Which hose is the inlet for heater core on a 97? The one coming from water pump or one coming out of tee off right head??
Old May 11, 2005 | 07:08 AM
mueckster's Avatar
mueckster
The one on the right head goes to the heater core inlet and the one to the waterpump is the return from the heater core. Just looked at this the other day, thinking about installing a vacuum-operated heater valve before the inlet for the summer.
Old May 11, 2005 | 11:34 PM
rockyrider's Avatar
rockyrider
Thanks, It's already hot here so I'm going to do mine this weekend. I'm going to install a shutoff valve I got from plumbing dept at Lowes in the inlet line. It is cheaper and quicker. Should work just fine. Anybody see any reason not to do it this way????????
Old May 12, 2005 | 07:47 AM
mueckster's Avatar
mueckster
Should work fine.
Old May 12, 2005 | 08:02 AM
blackf3504dr's Avatar
blackf3504dr
Should work ... Same setup on my Kenworth .
Old May 12, 2005 | 10:35 AM
RobertJohn's Avatar
RobertJohn
OK a question !
If you stop the flow to the heater core won't this cause it to corrode and possibly leak when the water supply is opened again ??
Also, if you put a shut off valve on the intake line won't this cause excessive pressure on that line ? Why not just do a loop outside the heater core like a "U" shaped connection between the intake and outlet ? But this would also cause corrsion wouldn't it ?
Just thinking ! Cause I also live in S. TX and it's hot already.
Old May 12, 2005 | 10:50 AM
MRBASS's Avatar
MRBASS
I have done this on the last 2 SD's i have owned and never had a problem. makes a big difference in the way the A/C works too..
Old May 12, 2005 | 10:56 AM
RobertJohn's Avatar
RobertJohn
Just putting a shut off valve on the heater inlet ??
Or looped it ?
Old May 12, 2005 | 11:03 AM
Max1775's Avatar
Max1775
We've alwys just put a valve on the inlet, never thought of looping it. Think about putting a coolant filter in at the same time? I think I'm going to do it on mine.
Max
Old May 12, 2005 | 11:09 AM
RobertJohn's Avatar
RobertJohn
Not to ask a dumb question, but what size is the heater hose ??
Old May 12, 2005 | 11:14 AM
tjbeggs's Avatar
tjbeggs
hose size is 5/8 inch.
do you have a switch for the vacum operated valve. i live in michigan so i still need my heater in the mornings. is there a way to open and close a valve.
thanks
tim
Old May 12, 2005 | 11:19 AM
tjbeggs's Avatar
tjbeggs
ok got to thinking about the switch question. do you or could you tie in with the heater controls so that when you want heat you put vacum to or remove vacum to allow the valve to open? has anybody done it this way?
Thinking is dangerous. add one more thing to the list to do to my truck.
tim
Old May 12, 2005 | 11:20 AM
RobertJohn's Avatar
RobertJohn
I don't have a vac switch.. I'll just use a valve. And it's not hot here in the mornings..
Old May 12, 2005 | 07:48 PM
scotwms's Avatar
scotwms
ok guys, I think I screwed up. I put the valve in the hose coming from the water pump. I read above that it should be on the hose coming from the right side of the block. Please confirm this. Oh buy the way I got a valve at autozone, it is for the international scout. it has a control on it so you can route it through the fire wall and control it in the cab. anyhow any info on the above problem let me know.
Old May 13, 2005 | 06:58 AM
mueckster's Avatar
mueckster
The vacuum operated valve only closes when the climate control is on max cool. The vacuum line for the door that closes for recirculating air is used to operate the valve. It does not close the valve when in the normal position. This type is sold as a kit (valve and hose), but could be made up yourself. A manual valve would stop coolant flow in all positions to eliminate the heat in normal and vent also.
scotwms, you have the valve after the heater core.
