Problems with EBPV on 96 PSD
Old Nov 25, 2005 | 09:50 AM
barebackjake's Avatar
barebackjake
if you gut the whole thing the egts will drop a little and flow will improve. i dont have a stock turbo on my truck anymore so i cant vouch for all the improvements, but i know other people that have had improvements over the change. its always a combination of the entire matched system that you will see the best gains over. just keep that in mind, so if you have a better flowing intake and exaust there will be gains with both but minimal with just one. it helps if you have your signature filled out so we know what you have. shimming the fuel pressure up to about 68psi helps throttle response quite a bit.
Old Nov 25, 2005 | 09:53 AM
puffer's Avatar
puffer
how do u do that the psi
Old Nov 26, 2005 | 11:40 PM
FarmboyAC's Avatar
FarmboyAC
Alright, thanks guys, found the plug and unplugged it, much better. Thanks again, Derek
Old Nov 27, 2005 | 07:20 AM
puffer's Avatar
puffer
if u unplug it do u want to unplug it when the engine is cold or warmed up? how do you know if its open?
Old Nov 27, 2005 | 08:25 AM
barebackjake
when you start your truck if you hear it come on wait till it goes off then unplug it or drive the truck and shut it down and unplug it. remember if you do it the second way that turbo is going to be HOT
Old Nov 27, 2005 | 03:14 PM
444dieselrod's Avatar
444dieselrod
Just go out there now with a flash lite and unplug it, you will prolly burn your hand if the engine is hot.
Diesel Rod
Old Nov 27, 2005 | 04:45 PM
puffer's Avatar
puffer
the plug is under the turbo it looks a 2 wire plug right between the inlet of the turbo
Ezalycasaid
Sep 14, 2016 01:05 PM
mrm8174
26
Aug 22, 2015 04:00 PM
jmunkie13
13
Aug 22, 2015 11:37 AM
BuckHammer
15
Feb 15, 2012 12:42 AM
Dutch Semi
Sep 30, 2011 10:50 AM
