Spark Plugs
Old Nov 23, 2005 | 03:44 PM
bigfish3's Avatar
bigfish3
Question Spark Plugs
03 Ranger Edge. 6cly. (code V) FFV, 5 speed Auto, 2WD.
Owners manual sez use AGSF-22PP for this engine. Is this the correct plug or only because you might use E85? A reg non V engine uses a -32PP.
I have also heard that the correct plug is AGSF12FMF6. This is 1 heat range cooler than the -22PP and 2 heat ranges colder than the -32PP. Any inputs on which would work best in my truck?
Old Nov 23, 2005 | 04:26 PM
el conquistador's Avatar
el conquistador
use whatever the owners manual says to use.
Old Nov 23, 2005 | 04:58 PM
RangerPilot's Avatar
RangerPilot
Use only their suggested plugs and ONLY Motorcraft brand plugs.
Old Nov 23, 2005 | 08:47 PM
Ken00's Avatar
Ken00
I'm running the fine wire 12s in my 3.0 with no problems, it called for 22s.
Old Nov 23, 2005 | 09:00 PM
Rockledge's Avatar
Rockledge
A lot of good and knowledgeable people (like Ken00) would even recommend a "colder" Motorcraft plug on the 3.0L vulcan, this is one of the ways to help fend off the annoying pinging that it is somewhat prone to.
The Motorcraft FM or "fine wire" series plugs are now the OEM replacements for Fords with the DIS/EDIS ignition systems, they take the place of the PP (double platinum) series plugs.
Old Nov 23, 2005 | 09:15 PM
bigfish3's Avatar
bigfish3
It appears that I can choose between either the 22FMF6 or the 12FMF6. Thanks everyone for sharing your thoughts. Much appreciated
Old Nov 24, 2005 | 12:32 AM
RangerPilot
Great that you got it, tell us how it runs once you get 'em switched out.
Old Nov 24, 2005 | 07:06 AM
Bob Ayers's Avatar
Bob Ayers
I'm using the 12FMF6s in my 1999 3.0L FFV, and they run fine!
Old Nov 24, 2005 | 07:23 AM
Bart99GT's Avatar
Bart99GT
Bob, do you experience any fouling with those colder plugs? My Dad has problems with his 3.0L pinging, especially in warmer weather. I have held off suggesting a colder plug to him simply because I'm concerned about plug fouling.
Old Nov 24, 2005 | 07:36 AM
Bob Ayers's Avatar
Bob Ayers
No problem with fouling at all. Matter of fact, my owner's manual calls out double platinum 12s as the replacement plugs. I tried the double platinum 22s at one time, and had a pinging problem. I pulled them after about 5K miles, and they looked "blistery" an indication they were running too hot. I've since run the double platinum 12s, and now the fine wire 12s, and they run fine.
Old Nov 24, 2005 | 05:24 PM
Ken00's Avatar
Ken00
Thats the reason I put them in mine, didn't help.
Old Mar 21, 2006 | 12:53 PM
jas88's Avatar
jas88
Would a colder plug help the 2.5L 4-cyl as well? I have a '98 B2500 and I just sea-foamed it but it still pings. I have the fine-wire 32s in mine.
Old Mar 21, 2006 | 08:45 PM
Ken00's Avatar
Ken00
I haven't heard of anyone trying it...yet.
funtwohunt
Oct 3, 2012 02:06 AM
ptf18
Oct 30, 2011 08:42 AM
ssjrsw
Jul 23, 2008 10:46 AM
Larry S
23
Jul 20, 2008 01:08 PM
Bob Ayers
20
Jun 22, 2003 03:02 PM
