2000 4.0L spark plug ????
Old Jan 6, 2010 | 06:04 PM
funtwohunt's Avatar
funtwohunt
Was looking at the Owners manual for the 2000 4.0L I just got and it is very specifis about when removing each plug for inspection you put it back in the same cylinder. It says that cylinders 1,2,&3 have a "PG" suffix, and 4,5 & 6 have a "P" suffix. Why is this? Also, I want to replace the plugs and the manual says to use only plugs with the service part number suffix letters "PP". It calls for Motorcraft AGSF-22PP. What other platinum plugs will work? What Bosch Platinum number will work? Thanks Funtwohunt
Old Jan 6, 2010 | 08:14 PM
Rockledge's Avatar
Rockledge
The plug differences have to do with the nature of the Ford "waste spark ignition" and polarity. See: Spark Plug Tech
Bosch spark plugs are not a good choice for the Ford "waste spark" ignition. Go with the currently recommended Motorcraft (part# SP500) or Autolite (part# APP-103) replacement plugs.
Old Jan 7, 2010 | 03:52 PM
KhanTyranitar's Avatar
KhanTyranitar
And no, do not use the crappy Bosch. Use the Motorcraft AGSF-22PP or equivalent, or Autolite APP103 or XP103. Do not waste your time and money with Bosch, NGK, Denso, or anything else.
Old Oct 3, 2012 | 02:06 AM
swshawaii's Avatar
swshawaii
Good info from the "Spark Plug Tech" link with this exception:
(Should read spark plug end terminals and inside wire boots)
Smear dielectric grease on the spark plug electrodes and tips to make them waterproof and prevent arcing.
dwildmanj
Aug 19, 2020 07:17 PM
packagerjr
May 26, 2017 07:43 AM
ptf18
Oct 30, 2011 08:42 AM
funtwohunt
Jan 6, 2010 08:14 PM
ssjrsw
Jul 23, 2008 10:46 AM
