Duraspark !
Old Nov 21, 2005 | 06:46 PM
brownstraightsix's Avatar
brownstraightsix
Duraspark !
Hi there, i have an 84` f-150 with a 300 straight six with a single barrel carb.
i had the EEC(electronic engine control) but when i put my hedder in, some sensors had to come out. So now, i switched it to a Duraspark II system. I changed the carb, ignition coil, distributor, ignition module and i redid all my wiring myself.
Here's my question! I found about 20 links on the internet for a red-white-orange-purpple-green-black color code but...
The colors coming out of my ignition module are
white
orange
purpple
black w/white stripe
black w/green stripe
green
Does anyone have the color code for this???? I've been stuck taking the bus for a week now, and it's getting cold...Can someone help me?
Thanks a lot
Old Nov 21, 2005 | 07:18 PM
javi2001's Avatar
javi2001
It seems to me this is not the proper distributor, standar Duraspark use purple, orange and black
Old Nov 21, 2005 | 08:36 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Where the wires come out of the duraspark II module, on 1981.,
  • orange / hooks up to the orange-yellow wire on distributor.
  • Black-Light Green / Hooks up to black-Light green Wire on Distributor
  • purple / hooks up to the Purple-Light blue wire on distributor.
  • Light Green / hooks up to a dark green-yellow wire that leads to the tach test wire on coil and goes to the instrument cluster connector.
  • Red Light blue / hooks to red light blue wire that goes from ignition switch start circut, gearshift newtral switch, (if so equipped) and hooks to the starter solonoid.
  • White Light Blue / goes to white light blue wire that hooks to the run circut on the ignition switch.
That leaves you one wire from the coil.
Red-Light Green / splits into two wires.
  • one hooks to a brown-pink wire that goes to and splices into a red-light green wire in the ignition switch circut.
  • the second goes through a 105-115 ohm resistor, goes to a three way splice (four for guages )
    • one goes to the fuse panel fuse #3 and #2 .
    • Two goes to the ignition switch
    • the third goes to the printed circut in the instrument cluster.
      • and with idiot lights only splices off the third wire and goes to a 500 ohm resistor, wire turns light green red that goes to the voltage regulator, and instrument cluster printed circut..
    • (fourth with guages only, color changes on fourth to Lt Green Red goes to voltage regulator, and the instrument cluster printed circut)
Hope this all helps you out.
Old Nov 21, 2005 | 08:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
Get a section of the wiring harness from a salvage yard and use the proper ford module connectors.
Old Nov 22, 2005 | 12:31 AM
Col Flashman's Avatar
Col Flashman
This is one of the reasons I like the Mallory adaptor kits to use in the Original Distributor, no hassle, no fuss. Just replace the Points w/ the Reluctor, then plug it in to the box & Boom you good to go.
Old Nov 22, 2005 | 01:30 AM
bigbrown84truck's Avatar
bigbrown84truck
hey col.... does mallory make a conversion kit to go from electronic feedback, to duraspark style? he is not trying to update his system, actully is pre dating it.... like alot of us with 84 to 86 trucks do so we can get rid of the junk electronic feedback carbs.
Old Nov 23, 2005 | 06:39 PM
brownstraightsix
Gee that's pretty explicit.
Thank you very much for the help
Old Nov 23, 2005 | 09:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
I like to use Duraspark because replacement parts are available anywhere and testing is available at most good parts stores.
Serfbored
37
Mar 9, 2021 09:48 PM
F250_Super_4X4
Dec 19, 2016 10:21 AM
svolpone
Apr 8, 2015 01:50 PM
piersol
Jun 5, 2010 06:59 PM
stevew15
Apr 8, 2006 02:54 PM
