Ok guys here it is. While replacing the shift indicator, I FUBARed my turn signal cam. Ended up cutting all of the wires. But I have an old "Signal Stat 900 Siggflare" that I would like to use. However none of the wire color match.
Here's what I have, wire colors in the truck - Solid blue, Blue w/yellow stripe, white w/blue stripe, orange w/blue stripe, solid green, green w/orange stripe and green w/white stripe.
The Signal Stat has the following color wires Blue, red, black, yellow, light green, white, grey w/black stripe.
Now, does anyone know what colors would match for proper operation?
My truck is a 65, 2wd, auto, w/o original hazard switch.
You can still get a new signal light switch at your local Ford dealer. The price isn't that bad. Why mess with a aftermarket switch when you can make it right with a correct part? Part number is C9TZ 13341-C. I got one for a member(Brider) here not that long ago. I work at a Ford dealer in Ct., and got it next day from our facing depot. If you want one, I can get it and ship it to you at a discounted price from list.
Send me a PM if you are interested.
