Motor Mounts
Old Feb 14, 2002 | 09:11 AM
Chip's Avatar
Chip
Motor Mounts
Does anyone know if there is a motor mount tower to allow me to install a 390 into a 1979 Ford Shortbox 4-wheel drive? If so, where I might locate them? Thanks in advance.
Old Feb 14, 2002 | 10:13 AM
rc351w's Avatar
rc351w
Motor Mounts
I don't know about aftermarket ones, but you can look in the salvage yards for '73 to '76 trucks that had 360/390's in them. They will work.
RCC
Old Feb 26, 2002 | 12:35 PM
jalampi's Avatar
jalampi
Motor Mounts
1st measure from your motor mount studs to the rear of the block on the factory motor.
Next on your FE 360/390 swap the motor mounts on the motor from left to right & measure from the motor mount studs to the back of the block.
Now measure back from holes in the motor mount towers & mark the difference from your 1st & 2nd measurement
& that is where you will drill & slot your new holes to mirror the existing ones.
Then weld closed the factor holes.
Next you will need to cut the rear of the driver side tower to make clearance for the left exhaust manifold.
Depending on how much you cut off there maybe need to do reinforcement of that tower.
You will of cores need a bell housing if you have a stick or an auto trans & starter.
The power steering pump will work from F150 but you will need the FE block bracket.
You may also need a relocater for your oil filter for clearance.
Next take the truck some where to have a custom exhaust made.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
Old Feb 26, 2002 | 06:26 PM
Mil1ion's Avatar
Mil1ion
Motor Mounts
562dragnhra
63
Aug 4, 2009 06:29 PM
Adam0331
28
May 17, 2009 09:25 PM
seth1
1983 - 2012 Ranger & B-Series
Jan 30, 2004 08:48 PM
jwtaylor
Sep 20, 2002 01:50 PM
Phillip Guidry
Oct 24, 1999 03:19 PM
