C'mon...I AM smarter than that but the fact is I didn't know the TRQ numbers.
Well actually the Dodge will probably have around 390HP & 440 lb ft in the trucks when it comes out. It will be tuned for TRQ in the truck. (A drop 425/420) Let me ask you...if you could trade 10lbs of torque for 40 more HP, would you? (I'm using the 350/450 3V V10 numbers)
We all know that the Escalade will come out with GMs new 6.2L all-aluminum V-8 engine with VVT delivering 403 horsepower and 417 lb.-ft. of torque.
No, the TRQ numbers are not close to the Triton V10 but still...
And yes, I know the curves are important.
One thing would be to Supercharge AND Turbocharge the V10. Watch what VW is doing with thier Twincharger engine. They think it could spell doom for the modern diesel in cars & light trucks.
More on Monsta's question about giving up 10 ft/lbs of torque for 40 HP:
Using my '01 V10 as an example:
310HP@4250 (I believe) means at 4250 RPM, there's 383 ft/lbs of torque.
Computing what RPM it would have to spin to get 350HP (40HP more) means I'd have to pull to 4928RPM to get that 350HP and 373 ft/lbs of torque.
Now, I know that's not exactly 10 ft/lbs less at PEAK, but you get the idea. I'd have to spin the V10 up to almost 5000RPM to get the 40 more HP with 10ft/lbs less torque.
To make up the difference, I'd have to regear to 3.82:1 to make up the torque loss.
Okay let's say that you didn't have to spin it for those numbers. Granted both those engines I talked about post those Peak HP numbers at above 5000.
However, if I didn't have to spin my V10 any higher to reach peak HP than I am now, I would trade 10lbs for 40 more HP up top. 350/415 are still good numbers.
My "arguement" of course didn't take RPMs into account. Fact is, a 390/440 truck engine is still a stout engine. If the numbers (RPMs) were the same I'd choose the 390/440 over the 350/450.
