Modular V10 (6.8l)
variable cam
Old Nov 19, 2005 | 12:38 PM
uuranium's Avatar
uuranium
variable cam
did ford put a variable cam in the v10 ever? if they didn't do you thin that they will and when?
Old Nov 19, 2005 | 12:59 PM
Fredvon4's Avatar
Fredvon4
No they have not yet...and THAT is the 64,000 dollar question!
Old Nov 19, 2005 | 01:02 PM
ford390gashog's Avatar
ford390gashog
i assume you mean the VVT used in the v-8. i hope ford uses that in the v-10 its not that hard, would gain some easy power.
Old Nov 19, 2005 | 09:05 PM
machanic's Avatar
machanic
I think the reason they have not done it yet is because of the variable intake runner system. I think when they can get it to work together seamlessly they will probly do it.
Old Nov 19, 2005 | 09:26 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's most likely a marketing thing... they are waiting for the next big gasser push by the other two major pickup makers, and put VVT on a 3-valve V10. Guess who wins?
After that, maybe a bigger bore/stroke.
Old Nov 20, 2005 | 06:46 AM
captchas's Avatar
captchas
Guest
i'd love to have it and a few more hp.
Old Nov 20, 2005 | 07:19 AM
FortyFords's Avatar
FortyFords
Becareful what you wish for,there have been some problems
Lots of electronics involved.
I'm a little skeptical of it,right now.
Rich
Old Nov 20, 2005 | 07:26 AM
Fredvon4's Avatar
Fredvon4
I am with 40Fords on the VVT... unless the system yields a significant HP and torque increase AND is super reliable I an not tooo keen on making this motor any more complicated.
For the next upgrade I hope Ford would consider is a mild factory Blower
Old Nov 20, 2005 | 12:57 PM
captchas's Avatar
captchas
Guest
ohhhhhyaaaa. that i'd love esp. since ford racing dropped the blower kit that they where going to offer
Old Nov 20, 2005 | 01:01 PM
krewat's Avatar
krewat
If they put a blower on that thing, they can kiss all their diesel sales goodbye!
The only thing saving the diesels at that point would be MPG, and with the differential in fuel costs right now, that wouldn't do it for a lot of people.
However, the 2-valve V10 already puts out enough power for a pickup, and the 3-valve is even better at the job. Towing the 3-valver is apparently such a good towing maching, that VVT might make up more of the difference.
I wonder how close the V10 crank is to max-sustainable high-mileage use? With a blower on it, that crank is going to get a good twistin', and the cross-bolted block is sure to squirm here and there. And they'll have to do something about the crank snout strength - here comes SUPER-V10 with a 2" snout for driving that blower !
Old Nov 20, 2005 | 01:17 PM
captchas's Avatar
captchas
Guest
if they don't offer a blower i hope they add 2 more holes to the block. any one thinking v12 gasser super duty?
Old Nov 20, 2005 | 01:21 PM
machanic's Avatar
machanic
yeah they have had problems with vvt. the contour had it and when they come in and the customer would not change their oil it could cause some issues. I think if they changed the bore and upped the comp ratio to the same as the 5.4 that would net probably 30-40 more ftlbs of torque. 360hp 500ftlbs of torque would be nice
Old Nov 20, 2005 | 01:28 PM
krewat's Avatar
krewat
Breaking 500ft/lbs with a naturally-aspirated gasser would be the holy grail
Especially if it can be done below the 3000RPM mark, and peak out around 525 at 3800
Old Nov 20, 2005 | 06:33 PM
uuranium's Avatar
uuranium
see iw as wondering because i am looking at hot rodding the v10 3valve and was worried that they had put the vvt on it because that just complicates things.
Old Nov 20, 2005 | 08:17 PM
Monsta's Avatar
Monsta
Sit. Stay.
Like a Z06 or the new Viper?
