1953-56 Panel truck rear door handles
Hadn't been able to work on Gracie since this topic came up, yesterday I needed to get into the back, and for the first time I noticed SHE HAS 2 INSIDE HANDLES! They do not match each other tho, the left one is smaller and attached with a bolt thru the top and into the end of the shaft. The right one is larger, heavier, straight, and attaches to the shaft with an allen head set screw to the side of the shaft. I suspect it is a later addition as there is no cover plate over the mechanism. (She also has chromed guides to hold the doors open.)
My inside handles are similar....2 non matching handles, with the drivers door (stock) one being smaller. I welded a short extension of square shaft on the end of the right door stock shaft and mounted a matching handle with a cotter pin onto it. The handle I used was, if I recall, a junk yard passenger door handle off an F1 (not sure exactly); it had a square shaft mount. This handle was a tad longer than the regular panel left door handle, but I preferred that, to make it easier to open and close.
Take a look at the handles that Spaenaur http://www.spaenaur.com sells, or try a local big truck parts supplier. I've been told that the square shaft can be bought as key stock at industrial suppliers.
0500757Arf
19
11-01-2015 07:19 AM
Lancester
10-07-2015 07:43 PM
cokeman
1999 to 2016 Super Duty
01-06-2014 04:26 PM
