1978 - 1996 Big Bronco
speed sensor
Old Nov 15, 2005 | 06:10 PM
whreq's Avatar
whreq
speed sensor
my speed indecator went to "0" at 35 mph. the truck got me home , but only in first gear. any ideas what may have caused this.
Old Nov 15, 2005 | 07:33 PM
greystreak92's Avatar
greystreak92
What year truck are we talking about here?
masseysbronco's Avatar
masseysbronco
you need to check for codes, but sounds like the Vehicle speed sensor, which is mounted in the top of the rear axle (87-96 i think). What year is your truck? you need to give us more info to work with.
Old Nov 15, 2005 | 08:50 PM
whreq's Avatar
whreq
sorry, 1994 . the ABS light came on also.
Old Nov 15, 2005 | 11:25 PM
greystreak92
Masseysbronco has it pegged then. VSS failure. Its in the top of the rear differential housing held in with a single bolt. Check the connection to it first and the wiring harness nearby for abrasions or other damage. If you find nothing, you can remove the sensor and trying wiping it down and re-installing it to see if the "cleaning" was all it needed. But from the way you described it, it up and quit on you or something came up and severed the wire(s) to it.
Pulling the codes won't hurt either, this way you can either confirm or deny that the VSS is indeed the culprit.
Old Nov 16, 2005 | 07:23 PM
whreq's Avatar
whreq
thanks for you help. i wont have time to work on it until this weekend, but i'll let you know. thanks again.
Old Nov 16, 2005 | 07:54 PM
Super-Dayv's Avatar
Super-Dayv
I have a speedometer question...I know when you change rear gears in a Mustang you can change the gear on the speed sensor so the speedometer is correct. Is it possible to do the same on the Bronco when the tire size has been increased? I just bought a 89 Bronco, A/T, 302, 3.55 limited slip gear with 31x10.5 on the stock wheels. I want to change wheels and go up to a 32x11.5 like my old 88 Bronco, but I know the speedo is already off 5 mph...is this possible?
Old Nov 22, 2005 | 09:28 PM
whreq's Avatar
whreq
thanks for the help. the new VSS got me going, but the ABS light is still on. any ideas? and is it safe to drive with the ABS light on?
Old Nov 23, 2005 | 07:18 PM
whreq's Avatar
whreq
ABS light is out, loose batt. wire, truck runs fine. i'm off to the woods. love to hunt and surf fish in my truck. thanks again.
Old Nov 28, 2005 | 01:24 AM
greystreak92
Actually, whreq, the reason your ABS light is out now is because when you disconnected the battery to fix the connections to it, you allowed the ABS computer to reset. This cleared the error code that was generated when the VSS failed. To clear the code youwould have had to disconnect the battery.
On your 89, yes, you can and HAVE TO regear the speedo to compensate. With 92 and newer Bronco's and F-sereis you need to reprogram the PSOM.
Old Nov 28, 2005 | 08:38 AM
Super-Dayv's Avatar
Super-Dayv
Thanks Greystreak92!
Old Nov 28, 2005 | 11:44 AM
Super-Dayv's Avatar
Super-Dayv
Greystreak92,
Do you have any idea which way I need to go or which gear I will need?
Old Nov 28, 2005 | 12:08 PM
greystreak92
Unfortunately, all of the trucks I have dealt with are PSOM-equipped. I do know that Ford made speedometer drive gears in different colors depending upon the number of cogs (teeth) they had but beyond that I've little experience actually doing the swap. Some of the guys here have done what you are needing to do to yours. I'm certain someone can give you some better insight than I can.
Old Nov 28, 2005 | 12:17 PM
Super-Dayv's Avatar
Super-Dayv
Thanks anyways, i know the colors have to do with the # of teeth. But I am not sure if i need to go bigger or smaller...like you said, hopefully somebody else has delt with this and will post shortly. Thanks again!
ANIMAL
Sep 4, 2002 03:31 PM
4_speed
Aug 25, 2002 11:20 AM
Yeti
May 17, 2002 04:16 PM
whiteboyslo
Nov 6, 2001 04:19 PM
slik
Oct 12, 2000 07:50 AM
