Water Pump
Old Nov 15, 2005 | 12:30 PM
Joey455's Avatar
Joey455
Exclamation Water Pump
Hi, i have a 1999 F-250 7.3 and the water pump quit on me is that something i can fix myself or should i take it to a pro? this is my first diesel by the way
Old Nov 15, 2005 | 12:41 PM
skibender's Avatar
skibender
How did it quit? That seems rather strange that it would lock up. Anyway, it's not too bad to change. There's lots of articles on the proper procedure to change one. I pulled my radiator out to change mine. Gave me a little more room to work but I know other guys have left their radiator in. The biggest problem I had was removing the fan blade from the shaft. It's on there pretty tight. I ordered a pump from one of the sponsors of this site plus I ordered a 203 degree thermostat also. It's suppose to be better for the diesel's to run a little hotter. Do a search - you'll find some good write-up's.
Old Nov 15, 2005 | 12:50 PM
Joey455's Avatar
Joey455
okay thanks for the help i think im gonna do it myself
Old Nov 15, 2005 | 12:53 PM
Fat Diesel's Avatar
Fat Diesel
I would call Bob Riley and get a pump, 203* thermo, and billet housing. The stock thermostat housing is a stamped steel pos. Bob seems to have the best prices on a new OEM pump.
Old Nov 15, 2005 | 12:55 PM
Joey455's Avatar
Joey455
does Bob Riley have a website or can i have the number please?
Old Nov 15, 2005 | 01:07 PM
Fat Diesel's Avatar
Fat Diesel
Check your email.
Old Nov 15, 2005 | 01:08 PM
wlihntr's Avatar
wlihntr
dieselsite.com
i have not replaced one yet but have heard many people say if you have replaced the water pump on other vehicles you can do it on a 7.3.
Old Nov 16, 2005 | 12:24 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Do A Search On This Forum.
Ther Are Several Good Threads About Changing Out The Water Pump.
Including Tool Sizes ,torque , Removal , Ect. , Ect
Old Nov 16, 2005 | 02:15 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yes, i search "7.3 powerstroke" on ebay, and half of the items seem to be water pumps. i would check ebay.
Old Nov 16, 2005 | 11:41 PM
nodakford's Avatar
nodakford
Changing the waterpump is not bad. Fan clutch nut can be a pain. Big thing is proper length bolt in right place and the don't use Ford manual torque. You will snap off the bolts. 18 lbs-ft of torque for the bolts.
Old Nov 16, 2005 | 11:54 PM
SpringerPop's Avatar
SpringerPop
Joey,
Note carefully what Nodak said, directly above.
The factory manuals have the wrong torque specs.
Pop
Old Nov 30, 2005 | 11:26 AM
Joey455's Avatar
Joey455
okay yeah i repleced it just went down to autozone and got one for about $300 made by cardone i know i should of looked around but i was in a hurry and my friend was helping me and dropped the fan and chipped the blade so i bought a new fan for 70$ so thanks for the help guys.
Old Nov 30, 2005 | 01:01 PM
skibender's Avatar
skibender
Watch for leaks for a couple days. I've seen many on this site experience leaks.
Old Nov 30, 2005 | 02:16 PM
4X4 IN REFUGIO
Yes ..... Watch For Leaks ...... Mainly At The Thermocouple Housing If You Did Not Replace With A New One When You Changed Out Your Pump.
They Are Notorious For Leaking Evan When The Old One Still Looks Good.
I Had To And Many Others Had To Go Back After The Fact And Go Buy One Because Of Leaks There.
bnmc98
Mar 20, 2010 09:23 AM
Polkster
Mar 12, 2009 04:39 PM
jconk5
Jul 16, 2005 04:11 PM
dmc919
May 12, 2004 06:48 PM
beckandyork
May 20, 2002 04:07 PM
