Water Pump
Old Mar 2, 2009 | 12:38 PM
Polkster's Avatar
Polkster
Water Pump
2000 f-450 7.3l
Leaking antifreeze from water pump area, hole in water pump leaks to warn of water pump is going out? Am i correct?
How long do i have before need water pump replaced? (probably silly question)
What type water pump to buy will last lomgest?
Old Mar 2, 2009 | 01:08 PM
aklim's Avatar
aklim
I got a pump from Pep Boys. Lifetime warranty and supposedly new and not reman.
Old Mar 2, 2009 | 01:38 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Water_Pump
I bought mine through them. Airtex is the OEM supplier, comes with everything you need (parts-wise; tools are your problem!! LOL) and they are quality. Lisa (Smokin') used one also I think, but others on this board will recommend not only that brand, but that sellor as well.
Old Mar 2, 2009 | 03:24 PM
mndiesel's Avatar
mndiesel
Originally Posted by papadelogan
Water_Pump
I bought mine through them. Airtex is the OEM supplier, comes with everything you need (parts-wise; tools are your problem!! LOL) and they are quality. Lisa (Smokin') used one also I think, but others on this board will recommend not only that brand, but that seller as well.
That is the one I bought and indeed it was from the same seller.
Old Mar 2, 2009 | 03:26 PM
just another truck's Avatar
just another truck
I couldnt wait, bought mine from Auto zone.. and if needed, they will loan you the tools..
Dont try to take any short cuts.. remove everything out of your way..
Old Mar 3, 2009 | 10:21 AM
Supercab's Avatar
Supercab
Wink
I think Northern Auto Parts (on Ebay) has the AIRTEX pumps, BRAND NEW, DON'T waste your time installing a reman. pump!!!
Old Mar 3, 2009 | 10:28 AM
mueckster's Avatar
mueckster
I got the same W/P from the same seller. I got it on sale (on their subscribed email list). Shipped to my door for ~100.
Old Mar 3, 2009 | 12:09 PM
MikeWorcester911's Avatar
MikeWorcester911
Is the beginning leak a typical precursor to the pump failing? And if so, about how much time is there usually?
Also, am I correct in thinking that the pump is under more stress when the rest of the engine is running hard, ie towing? If I have a leak, is it more likely to fail while towing or same as daily driving?
Old Mar 11, 2009 | 10:34 PM
MikeWorcester911
bump bump bump...seems important to me!
Old Mar 12, 2009 | 06:41 AM
aklim's Avatar
aklim
How much time is hard to say. I had a leak that lasted for 3000 miles but I was at home mainly so I could get it fixed easily. OTOH, I had another vehicle that went to hell in 100 miles from a leak to seizing up
Old Mar 12, 2009 | 09:05 AM
Polkster's Avatar
Polkster
Thanks for the help guys, i have my water pump in hand and have ordered billet aluminum housing and 203* thermostat.
I recieved 2 replies with instructions on water pump replacement, one was a document and other was a youtube link, They are not posted now, why would they have been removed, the youtube instructions were what i was going to use.
I go to this morning to write descriptions down to start removeal of pump and the replies are not here???
Did the administrator remove them for some reason?
Did the member remove them (2 diff replies)?
Please explain.
Old Mar 12, 2009 | 09:09 AM
Ponyboychris's Avatar
Ponyboychris
Here's some good instructions:
Waterpump Replacement 7.3
Old Mar 12, 2009 | 09:12 AM
novice psd's Avatar
novice psd
Mine never leaked until it went. I had heard a squeak at times then about 1 1/2 miles from home it really made a racket and antifreeze flooding out. O'Rielly also has new airtex. It's a good idea to remove the radiator or a least place something to protect it. I nearly punched a hole in mine. Good luck.
Old Mar 12, 2009 | 09:38 AM
brian42's Avatar
brian42
Veteran: Navy
Don't Forget To...
Get some gasket material for the union. The gasket/o-ring supplied won't be enough to seal the joint. The perfectly smooth billet housing does not mate well with the cast iron of the pump/block. Use some of the Permatex gasket material around the mating surface and let it skin up for about 1/2 hour, then put the thermostat in (w/the rubber gasket) and bolt the flange (billet housing) together. Wait as long as you can before putting the upper hose on the billet housing to give the Permatex time to cure. Then attach the hoses and fill the system.
If you don't do this now, you will be doing this later. Don't ask me how I know...
Old Mar 12, 2009 | 04:39 PM
danskool's Avatar
danskool
Go Bills !
https://www.ford-trucks.com/forums/8...ater-pump.html. The thread you were referring to? it appears they all work
here is your previous thread . It went south due to inactivity. https://www.ford-trucks.com/forums/8...ml#post7241575
Please explain.
tmill28
16
Apr 7, 2024 09:31 PM
jerryparks
May 3, 2015 06:58 PM
Dan Drover
Jul 15, 2014 11:55 AM
Marauder2004
Jun 30, 2014 07:17 PM
