1993 F150 Key cylinder removal
Old 11-14-2005, 06:38 PM
ronstep's Avatar
ronstep
ronstep is offline
How do I remove the ignition cylinder in a 1993 F150 (4x4, auto trans, tilt wheel,cruise control) if it wont move to the on or accessories position? I have a new one to replace it, but can't get the old one to move allowing me to press the release pin. Any help is greatly appreciated. Thanks!
Old 11-14-2005, 08:02 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
if you cannot use release pin than you need to do this:
-disconnect batt. ground cable
-using channel locks or vise grip pliers, twist lock cyl. cap until it seperates from the lock cylinder
-use a 3/8 inch dia. drill, drill down middle of ign. lock key slot approximatly 44mm (1-3/4 inch) until lock cyl. breaks loose from breakaway base odf lock cylinder. emove lock cyl. and drill shavings and other foriegn materials from casing
-inspect lock cyl. housing for damage from above operation
now you are ready to put in new lock cyl.
good luck.
Old 11-15-2005, 03:03 PM
93f250-44cepeks-olf-olf's Avatar
93f250-44cepeks-olf-olf is offline
move the old key around in there as much as you can while trying to turn the cylinder. you may get lucky.
greasemanicure
02-22-2016 08:09 PM
gameover1974
General Automotive Discussion
11-26-2015 10:43 PM
BAUJEF
10-26-2003 07:07 PM
Jakeman68
12-08-2002 06:24 PM
icy_wolf
03-26-2002 03:27 PM
Quick Reply: 1993 F150 Key cylinder removal
