Walker Downpipe
Old Nov 29, 2005 | 12:41 PM
  #31
red high boy's Avatar
red high boy
Lightbulb Walker down pipe 45166 on 1977 f250 4x4 highboy
Walker down pipe 45166 on 1977 f250 4x4 highboy. I made it fit. It took some work straightened out the main bend and flatened a small area that would have hit the frame. I think that this downpipe can be made to fit any year ford truck with a 240-300 six and efi manifolds. My truck runs way better 2.5 inch pipe and a two chamber flowmaster.
Old Nov 29, 2005 | 03:58 PM
  #32
5_labsownus's Avatar
5_labsownus
FYI to open up my downpipe I used a drum grinding stone (about 1 inch across and 1.25 long) and put it in a drill bit extension and and electric drill. It too about 10 minutes to clean it up!
Old Dec 1, 2005 | 12:49 PM
  #33
Oscar Meier's Avatar
Oscar Meier
I did the same thing - look in my gallery and I have a picture of the walker rear pipe connection and the poor hole in the 2.5" pipe.
Old Dec 1, 2005 | 02:26 PM
  #34
jgetti's Avatar
jgetti
I had the exact same issue too. I made quick word of it with the trusty ol stick welder. Just cranked it up to 200 and had it blown out in no time. I also noticed that the flanges were over a quarter inch off from matching up. However,, when I installed the header bolds, I just drew them down, and it basically formed itself to a tight seal. Avoided putting all the dents in it.
An unrelated issue with the downpipe is that I had a heck of a time trying to get it installed with the engine already set in the truck. It ended up that I had to cut 2" off the end of it just to get it past the crossmember.
Old Dec 1, 2005 | 02:49 PM
  #35
Roushians's Avatar
Roushians
Uh oh, I don't want to hear this stuff! I really hope mine bolts up nicely to the flanges. (I haven't done anything yet as I've been busy with a 6" lift install, but have vacation time coming up soon).
Old Dec 1, 2005 | 04:24 PM
  #36
jgetti's Avatar
jgetti
It was much less of a pain than I thought it was going to be. As soon as I started cranking the exhaust flange nuts on, they formed right into place and got a good seal the first time.
Old Dec 1, 2005 | 10:20 PM
  #37
flat4vw's Avatar
flat4vw
I just picked up my Walker 45166 from the parts store today. There is almost no restriction in mine - in fact there is so little i probably wont touch it. Its a clean cut, round enough with very little "flash" or excess metal. Maybe they've kicked it up a notch or maybe i just got lucky.
By the way - around here, it doesnt work to say "can you search for part # 45166?" It didnt show up in the 3 parts stores i went to. I finally found an Advance where the parts dork didn't **** me off and he actually let me try to help him find it on the computer. Its under "catalytic converters" --> "replacement pipe for universal cat." Sure enough, the part number right next to it was 45166, and when i picked it up today it had two stickers with the # on it.
Props to Advance - got it in a day before they said they would and it was $65 out the door.
Old Dec 2, 2005 | 01:22 PM
  #38
5_labsownus
If the parts guy will do a search in the system for "non-store" nimbers and enter 45166 it will list about 5 items and one will be the downpipe.
I did not have any problem getting the pipe in place! I used a new set of manifold studs from ARP (for a 302 I think - will look) and was able to hing the intake on them. Then slide the EFIs up and hold things in place with a couple of nuts. Then put the down pipe in place and put the nuts on the down studs to hold them up. After that I started to tighten things and make sure all in lined up!
Old Dec 2, 2005 | 02:49 PM
  #39
Bdox's Avatar
Bdox
You describe an excellent procedure for exhaust systems. I've done a ton of them, and I have found that you make your life easier and do a better job by putting the entire system together without tightening any of the fasteners until you are satisfied that everything is aligned and in place. Then tighten up the hangers and last tighten the connections. That way nothing is under any strain and the system won't rattle and the parts will last longer.
Old Dec 2, 2005 | 03:58 PM
  #40
5_labsownus
One more thing is to use a torque wrench and tighten the bolts/nuts and then start and warm the engine to operating temperature. After 15 minutes shut the engine off and re-torque the bolts/nuts! I made the mistake of not re-checking the first time and had to install a new gasket. I re-checked the torque and have not had a problem!
oldhalftons
22
Apr 20, 2016 01:50 PM
rkmaxwel
1983 - 2012 Ranger & B-Series
Jan 23, 2016 09:44 AM
MattEich
Oct 26, 2015 02:10 PM
Vegas123
Aug 5, 2015 08:50 PM
