A walker downpipe is something that connects to the flanges on the exhaust manifolds, and bents down towards the rear with a flange where the first cat should be connected, right?
If so, I NEED ONE TO CREATE MY CUSTOM FULL EXHAUST!!
heh
I was wondering about when i get my offy intake and the efi exaust manifolds..does it all bolt onto the block without trouble? And i can use the same kind of gasket right?
Any EFIs will work and for the most part there is only one pair. A minor difference is CA emissions vehicles may have an extra port in the front manifold!
One note is the alternator may need bolted in the bracket and then the bracket/alternator mounted. The long bolt runs from the back to front!
