simple oil checking question
Old Nov 11, 2005 | 11:39 AM
goodwrench's Avatar
goodwrench
I noticed my 300 has a long safe range. Is it a quart from add to full like most others? And how far down the stick should i let it go before i add any to it? I have always heard all the way to the add, but i never go more that 3/4 of a quart low. What does everbody else do?
Later!! chris
Old Nov 11, 2005 | 12:05 PM
300 4 ever's Avatar
300 4 ever
It is 1 quart from thetop to the bottom of chekered area. I check mine and add accordingly based on where the level is at. It shouldn't matter for our applications if it is a little overfilled. Everytime I change my oil I just put in 6 quarts and new filter and I don't check it afterwards. I know, bad habit, but I've changed it enough to know that 6 quarts with a new filter will bring it right up to the top level.
Old Nov 11, 2005 | 09:22 PM
Kista20's Avatar
Kista20
you are correct it does take 6 quarts for an oil change and it does take 1 qt between the add and full marks.
petro1
6.7L Power Stroke Diesel
Aug 24, 2011 05:17 PM
NWO_diesel_nut
25
May 23, 2011 12:48 PM
claycomotrucks1991
Jun 17, 2009 07:17 AM
410 Highboy
Apr 29, 2009 01:38 PM
jd_sylvia
Feb 17, 2006 11:08 AM
