Offroad & 4x4
winch
Old Nov 10, 2005 | 07:57 PM
kjg26's Avatar
kjg26
winch
i'm looking into getting a mile marker winch. i've made up my mind on the brand, so... what's the difference between the Mile Marker SE12000 and the E12000?
Keith
Old Nov 10, 2005 | 08:06 PM
fishmanndotcom's Avatar
fishmanndotcom
i lived in alpharetta for 10 years! glad to see someone from yuppieville posting in an off-road forum
Originally Posted by MileMarker website
SE 12000...
Features
Planetary gear system for fast line speed.
Automatic load holding brake. Free spooling
Power in and power out 3.6kw (4.8 hp) heavy duty series wound DC motor. Low electric current. Hardened drum.
Specifications
Rated line pull (single line) 12,000 lbs. (5,400 kgs.)
Gear Reduction ratio 294:1
Motor (Series Wound) 3.6 kw (4.8 hp), 12 volt and 24 volt DC
Drum Size: Diameter/Length 2.64 in (67 mm) x 9 in (228 mm)
Cable supplied (min break force 14,400 lbs nominal) 3/8 in (9.53 mm) x 100 ft. (30.5 m) aircraft cable
Overall Dimension (LxWxH) 22.1 in x 6.5 in x 7.3 in (559 mm x 165 mm x 173.5 mm)
Net Weight 86 lb (39 kg)
Mounting bolt pattern 10 in x 4.5 in (254 mm x 114.3 mm)
E12000
Features
Limited 2 year warranty, 3-stage planetary gear system for fast line speed, Freespooling. Automatic load-holding brake. Power In and Power Out. Roller fairlead. 12 Ft Handheld Remote Switch.
Specifications
Gear Train Planetary -265:1
Overall Dimensions {LxWxH} 21.3 in x 6.3 in x 8.3 in [542 mm x 160 mm x 218 mm]
Motor Series wound, 5.5HP
Cable 3/8" x 100' (14,400 lbs. nominal) Galvanized Aircraft Cable With Replaceable Hook.
thats straight from the website
-cutts-
Old Nov 10, 2005 | 08:15 PM
fishmanndotcom
if i had to guess, from the looks i'd say the E12000 looks a lil more stout just from the engage/disengage lever and you get a real remote with instead of the cheesy rubber hand control
-cutts-
Old Nov 11, 2005 | 10:06 PM
DernMooseAk's Avatar
DernMooseAk
SE12000 is 4.8 hp gear reduction 294:1
E12000 is 5.5 hp gear reduction 261:1
And of course the cheesy rubber handle thing....
jonrjen
6.7L Power Stroke Diesel
30
Jun 23, 2015 07:54 AM
v10tritanium
Apr 7, 2015 05:41 AM
bigred66
Apr 1, 2011 12:52 PM
MagKarl
Mar 25, 2009 10:50 AM
96bronco58
Offroad & 4x4
Oct 21, 2004 09:35 PM
